What paint do I use for console and dash panels?
Old Aug 30, 2009 | 09:47 PM
FLORIDA's Avatar
FLORIDA
St. Jude Donor '07
Default What paint do I use for console and dash panels?
What paint do I use for console and dash panels? Also where do I find it.
Old Aug 30, 2009 | 11:02 PM
NeutronVette's Avatar
NeutronVette
black paint i think
Old Aug 30, 2009 | 11:51 PM
tlc0706's Avatar
tlc0706
I used regular car color matched to color code by an auto paint store.....going to the painter this week, he may want flex agent....will notify you when I know.....used to be a lot of threads on this / try the search feature....GL
Old Aug 31, 2009 | 12:42 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
SEM makes interior dyes. Make absolutely sure you clean the surface well. Use detergents and even acetone, but check for color fastness (paint wiping off from the acetone). Paints don't like silicones (Armor All and the like). Silicones will fisheye your paint and make you throw things across the garage. Also, I recommend a coat of Bulldog adhesion promoter prior to spraying the dye. Then top it off with a clear coat. PPG and other large paint manufacturers also make interior dyes that you can have custom mixed and matched at paint supply shops.
Old Aug 31, 2009 | 01:47 PM
Corvettes of Dallas - Parts's Avatar
0Corvettes of Dallas - Parts
Former Vendor
Make sure to prep everything properly, that will be the most important.
-Adam
Old Aug 31, 2009 | 04:30 PM
FLORIDA's Avatar
FLORIDA
St. Jude Donor '07
Thanks. Found SEM on Ebay.
Old Aug 31, 2009 | 04:51 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
step into the audio section; the double din/nav C5 guys do this all the time when the mod the console, they should have a nice "how to"
To What paint do I use for console and dash panels?
