Long Vs Short Injector ?
Old Aug 31, 2009 | 10:29 AM
Hvymtlc5's Avatar
Hvymtlc5
Default Long Vs Short Injector ?
What is the difference in a long injector vice a short LS1 injector? Is the long EV1 injector a direct drop in (no rigging) or do I need shorts?
Old Aug 31, 2009 | 01:55 PM
zeevette's Avatar
zeevette
You can't put significantly shorter injectors on your stock fuel rails, or they won't bolt back down. I would think longers ones would be a problem as well. I got aftermarket Racetronics, which were only about 1/32 longer, and they barely seated into the FAST manifold, not sure about the stock LS6 mani.
Old Aug 31, 2009 | 02:04 PM
Hvymtlc5's Avatar
Hvymtlc5
Just trying to figure out when a compnay say says they have a long injector for the LS1 and short injector....which one does the stock LS1 fuel rail use.
looking at these:
http://www.bmotorsports.com/shop/pro...roducts_id/448
Old Aug 31, 2009 | 04:59 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
60 pounds per hours is a pretty big injector, what are you building?
Old Aug 31, 2009 | 05:08 PM
zeevette's Avatar
zeevette
According to their specs, the electrical plug is compatible, but this doesn't address the length issue. At the bottom is a list of equivalent models. If the factory ones are on the list, then OK, but....
I think the long/short LS1 reference was to the earlier, versus later models. They changed to a non-return fuel system about 1999 and maybe the rail was different then?
Old Sep 1, 2009 | 08:02 AM
Hvymtlc5's Avatar
Hvymtlc5
I have a forged 383, with Procharger...that is out of gas at 4800 RPM (577 hp btw ). Working on fuel upgrades....
I thought this injector fitment issue would be simple to figure out...anyone else?
Old Sep 1, 2009 | 11:34 AM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
If you're looking for an LS1 length 60# Injector EV1, we carry the FAST 60's ($375). They're actually the same thing as Siemens. This is a direct replacement for an LS1/LS6 fuel rail. In stock.
http://forums.corvetteforum.com/c5-t...emens-svo.html
Feel free to contact me with any questions.
Seth
To Long Vs Short Injector ?
