Hazzard switch wont stay
Old Aug 31, 2009 | 10:44 AM
omegac1's Avatar
omegac1
Default Hazzard switch wont stay
I bought a used 2003 C5 and the hazzard light switch by the center vent will not lock into place. I assume that there is some "click" that holds it in the dash but when you push the switch, the whole assembly pushes in. Anyone else have this problem before?
I understand that it is a pain to replace this switch. You would think that the center vent with the hazzard switch would pull out for the front?
Old Aug 31, 2009 | 11:46 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You have to pull the entire cover off of the dash to access it. Sounds to me like someone took a short cut and use the screwdriver trick to knock out the hazard switch and broke the retainer.
Old Aug 31, 2009 | 12:19 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yeah, I agree...sounds like the previous owner messed up the surround.
To Hazzard switch wont stay
