02 Sensor extentions
Old Sep 11, 2009 | 03:00 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Originally Posted by dancin1
I just got my OBX headers installed also. We used the front O2 sensors in the front with O2 extensions (flat connector for fronts, square for rear) and plugged the rear ones. Got the extensions from Speed Inc, great service there. Only problem was the check engine light, no error codes on the DIC. Now the computer is at ECS for tuning and I can't wait for it to return. The friend who installed the headers does a lot of these and even custom builds headers and was pretty much impressed with these, especially for the price.
That's normal when you plug the rears w/out tuning them out
Old Oct 1, 2009 | 09:25 PM
jaybar's Avatar
jaybar
I ordered a OBX header package today. I have read all the posts and have a few questions. The how to on LS1tech says to remove the alternator and take the driver side stock header out from the bottom is this the same method to use with the obx item.
Secondly does anyone have a picture of what the hole cut it the tunel plate cover looks like.
I have to get everything ready ahead of time as my use of a lift is for a very limited time.
I have to find a plug for the rear o2 sensors and a plug/plate for the AIR tube as I don't plan to hook them up. Any idea where I can buy these things on-line?
Oh one more thing obx says they include a head to header gasket is it worth using or should I purchase one form GM?
Thanks,
JayB
Old Oct 1, 2009 | 10:17 PM
minitech's Avatar
minitech
I have a set of 2 o2 sensor extensions and a set of 2 o2 sims if anyone needs them 50 , 90 shipped to the lower 48.
Old Oct 1, 2009 | 11:36 PM
red83's Avatar
red83
Thanks,
JayB
gm gasket.
18mm toyota oil pan plug for the 02 block off
a.i.r block off plate...try sjm manufacturing. i think
