'04 Climate Control Illumination bulb type
Aug 31, 2009 | 06:42 PM
I have an '04 and the illumination (not the display, it's fine) does not work. I did a search and read through the various write-ups, but wasn't sure what type of bulb is used in the late C5 climate control illumination as I saw two different types mentioned.
Is it a solder in type LED or is it the push in style ? If it's the solder type, I would have to have someone else do it, but the push type I would happily tackle.
Thanks in advance,
Ernie
Aug 31, 2009 | 07:35 PM
They are solder type bulbs
Aug 31, 2009 | 08:48 PM
solder type!
Aug 31, 2009 | 10:52 PM
Wounded Warrior Escort '11
The best match is a 70ma 12vdc lamp. Forum member "Tstar" has the best source of supply for the lamps.
Sep 2, 2009 | 04:20 PM
Thanks for the info ! Is this something a soldering newb should attempt ? I've done some basic stuff, but not skilled by any means whatsoever.
Sep 2, 2009 | 05:38 PM
St. Jude Donor '11-'12-'13-'14-'15
Sure if you have some experience and the tools... no problem! A low wattage pencil iron and a solder sucker will do the trick!
Remember to replace all 14 at once or you'll be in there replacing more shortly afterwards...
http://www.mcmaster.com/#1505k414/=3gljkm
Sep 2, 2009 | 06:03 PM
Cool, thanks for the link and info !! I'm surprised they're not LED's, but miniature incandescents.
-Ernie
Sep 2, 2009 | 06:20 PM
Yeah that's why the LED Mod is so popular... BIG difference.
Tim
Sep 9, 2009 | 09:45 PM
where is the how too on this thread? I cant see my climate control at all.
Sep 9, 2009 | 11:20 PM
Quote:
Originally Posted by
ZEX-Z
Sep 10, 2009 | 01:30 AM
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
ZEX-Z
http://www.shop.jwmotoring.com/produ...&categoryId=15
