Brake rotors.
Old Sep 1, 2009 | 09:58 AM
540 vette's Avatar
540 vette
Default Brake rotors.
Anyone have a recommendation for slotted and drilled rotors without breaking the bank. I need front and rears.
Old Sep 1, 2009 | 11:04 AM
Oldvetter's Avatar
Oldvetter
Try brakeperformance.com
Use zinc plated rotors, especially if they are slotted and drilled. This prevents the surfaces from rusting.
Drilled are only for looks, but I run them. DO NOT use drilled rotors on the track.
Slotted rotors prevent uneven brake deposits which cause pulsating brakes.
Old Sep 1, 2009 | 11:27 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Originally Posted by maggie01
I would avoid drilled rotors; they not only take away braking surface area, but add nothing in return.
The new CTS-V and Viper ACR both come from the factory with slotted-only rotors.
I can't speak on the Viper, but the new CTS-V comes with solid rotors, no hole, no slots.
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Just like everyone else has said, the drilled rotors do nothing for performance. If you're looking for a nice quality long lasting Rotor, I would recommend Power Slot Cyro-Treated Rotors (Slotted). They resist warping and cracking while lasting 2-3 times longer than a traditional Rotor.
You can view all of our prices here http://forums.corvetteforum.com/c5-p...d-special.html
Feel free to contact me with any questions.
Seth
Old Sep 1, 2009 | 03:48 PM
ALVETTE00's Avatar
ALVETTE00
I have the PowerSlot Cryo's as well.
I like em!
Old Sep 1, 2009 | 05:14 PM
pcbunn's Avatar
pcbunn
Before you make your decision, do yourself a favor and check out Baer EradiSpeed rotors.
Old Sep 1, 2009 | 05:16 PM
03z06BLK's Avatar
03z06BLK
I just put these on my car. slotted and drilled with hawk hps pads
Old Sep 1, 2009 | 05:36 PM
HowlinC5's Avatar
HowlinC5
Go to www.raceshopper.com those guys are great. you have to email them for pricing but they are quick to respond. They machine rotors to order. I have a set of their drilled and slotted that I have had for 3 years and I drag race the car and have had no problems. Think I paid $230 shipped for fronts. They look better than the baer's IMO.
Old Sep 1, 2009 | 11:38 PM
540 vette's Avatar
540 vette
The new CTS-V and Viper ACR both come from the factory with slotted-only rotors. I have PowerSlots, which are cadmium-plated, not simply zinc-washed. Please, don't cheapen out on rotors. They are one of the most important components on our C5s.
One question, how much did you spend on rotors for your daily driver. I payed $50 each for the ones on mine. They have been working fine for 2 years now. Another question....I don't race my vette, I usually drive it the same as I would drive any other car. So what is the difference.
Old Sep 2, 2009 | 01:09 PM
pcbunn's Avatar
pcbunn
In my opinion warped rotors are often the result of improper lug nut installation not overheating, at least not on the street. I've watched installers over torque lugs unevenly on several occasions, resulting in a warped and pulsating brake pedal.
On another note, alot of very high end cars come with drilled rotors, even the newer ZO6 models as well as AMG Mercedes so I doubt that newer drilled rotors which are stress relieved are prone to the problems that occured with early editions. And I also doubt that a competent company such as Baer would sell rotors that proved to be defective. I've had a set of Baer Eradispeed rotors on my '01 for several years and driven the 'hard on brakes' Hwy 1 to Monterey loop numerous times without any issues. In fact I would suggest that drilled rotors actually run cooler than just slotted or plain without any noticable reduction in braking. Just my 2 cents worth!
Old Sep 2, 2009 | 01:16 PM
VETTEHIGH's Avatar
VETTEHIGH
Have 13" all around and love them
Old Sep 3, 2009 | 12:14 AM
HowlinC5's Avatar
HowlinC5
All I know is that my car stops way better than it did before the rotors and the drilled holes aren't for braking power as much as cooler operating temps, my rotors don't get nearly as hot which is better for wheel bearings among other things (i'm sure we all know what those cost to replace), so there is more to it than "bling".
Old Sep 3, 2009 | 04:31 AM
longdaddy's Avatar
longdaddy
what he said. if you warped rotors (especially more than once), any rotors - chinese $45 ones or fancy 2-piece $1000 setup, you likely have a problem elsewhere and throwing more money at the rotors will not solve it.
Old Sep 3, 2009 | 06:39 PM
TEXHAWK0's Avatar
TEXHAWK0
Unless you want drilled and/or slotted rotors just for show, just stay with solid rotors.
Old Sep 3, 2009 | 09:32 PM
auctiondepot's Avatar
auctiondepot
There is no such thing a warped rotors, what happens is the hot rotor inpegnates unevenly cause an uneven coeficeint of friction on the face of the rotor. I went through 3 rear rotors before changing them for the front rotors from a C6. I now have amazing brakes on the C5.
The conventional parking brake is lost forever, however there are parking brake calipers like on the Vipers and Ferrari's, that are adapted.
For about $200 a side.
See this
To Brake rotors.
