Modules for a Remote Starter?
Old Sep 3, 2009 | 10:07 PM
Fritz96's Avatar
Fritz96
Default Modules for a Remote Starter?
I'm looking to have a remote starter with door lock/unlock (no alarm) installed in my car. The shop said it needed at least 1 module as well...can anyone confirm this, and if accurate is 1 enough? Thanks.
Old Sep 4, 2009 | 02:32 PM
Mike Mercury's Avatar
Mike Mercury
you'll need a bypass module for the VATS ANTI-THEFT System
Old Sep 4, 2009 | 02:37 PM
Fritz96's Avatar
Fritz96
Thanks, will this be the only module I need? About how much are modules?
Old Sep 4, 2009 | 02:54 PM
dougbfresh's Avatar
dougbfresh
You can solder in a resistor the same value as your key.
Old Sep 7, 2009 | 09:49 AM
Fritz96's Avatar
Fritz96
Any more opinions?
Old Sep 10, 2009 | 08:31 PM
Mike Mercury
true, but that perma-disables the VATS system.. The "module" kinda does the same (substitutes in a resistor) but it only does this when a remote start command had been received. Any other condition and the VATS it still in good working order.
To Modules for a Remote Starter?
