? about rotors and calipers...
Old Sep 4, 2009 | 09:53 AM
Stealthlabel's Avatar
Stealthlabel
Default ? about rotors and calipers...
i was wondering if it is possible to fit c6 (non-z06) rotors and calipers on a c5?? do they just bolt on or is there other stuff that has to happen??
Old Sep 4, 2009 | 09:58 AM
slothy's Avatar
slothy
z51 brakes will need brackets, and i believe the c6 (non z06) is same as c5 - so would be changing parts out for nothing.
Old Sep 4, 2009 | 03:01 PM
dougbfresh's Avatar
dougbfresh
Why would you do this?
Old Sep 4, 2009 | 11:54 PM
argonaut's Avatar
argonaut
The stock C5 size rotor is 12.75 x 1.25, the C6 base is the same. The C6 Z51 is 13.37 x 1.25 and will bolt right up with a different bracket. The C6 base and Z51 calipers are a slight redesign from the C5, they are stiffer and hold up better on the race track.
The C6 Z06 of course is a whole different animal.
For most uses you would gain nothing with going to C6 non-Z06 calipers and rotors.
Old Sep 5, 2009 | 07:27 AM
AU N EGL's Avatar
AU N EGL
Many ppl put the C6 caliper on the C5. The C6 caliper is a little stronger in the construction.
The C6Z51 is just a slightly larger rotor which needs a different caliper bracket, but the same caliper
Old Sep 5, 2009 | 11:13 AM
nickolbag's Avatar
nickolbag
Do the c6z just bolt right up with a different bracket and 18" wheel to clear?
Old Sep 5, 2009 | 11:33 AM
AU N EGL's Avatar
AU N EGL
No. Need the C6Z calipers, mounting brackets and rotors.
18" wheels with the proper Off set, so not just any 18" wheel will work
Old Sep 5, 2009 | 11:37 AM
nickolbag's Avatar
nickolbag
How does the c6z stuff compare ot aftermarket stuff for out cars?
Old Sep 6, 2009 | 11:33 AM
sothpaw2's Avatar
sothpaw2
So for the C5 you can get the stronger C6 caliper without even changing brackets, it will bolt right up? Only the Z51 needs a bracket? Sounds like a good deal.
When do you know for sure when calipers need replacing from spread--is it just a pad taper thing?
Old Sep 6, 2009 | 06:08 PM
NemesisC5's Avatar
NemesisC5
Fronts calipers more robust only, correct? The rears are the same?
To ? about rotors and calipers...
