I am working to build a C5R and the body panels are currently being hand produced. This will widen my C5 by a good 6". Replacing the control arms would allow me to maintain stock sized wheels and overcome the recessed look that would accompany installing the fenders. Does anyone have any experience with a wider C5front end? or possibly some ideas on the best way to achieve a flush look between my wheels and new fenders. I haven't been able to locate a source for A/M control arms that would correct for this. Any input is appreciated, thanks guys.
They would have to be custom made, no products like that currently offered that I know of.
My want to contact Katech or Pratt-Miller and see if they have anything.
I have a wide body vette and just use after market rims made to fit.
you will also need many MANY other parts to make it work.
Your right, I didn't want to keep stock rims but I hadn't found any wheels with a size / style mix that would work. AU N EGL, where did you get your wheels from? I'm thinking maybe that's the better bet.
You're more or less into custom wheels here. Many of the higher end wheel companies will do custom wheels. Places like CCW (complete custom wheel) or Foose to randomly name 2that would make what you want. I think AU N EGL might have meant BBS - www.bbs.com - and I'd think they would build to fit too.
Talking suspension geometry. Won't a wheel that puts more rubber to the outside of the stock design change parts of the suspension geometry for the worse too?
all mine are CCW Classics.
one set of CCW Classic Street 18x10 18x275/35 and 18x12 18x335/30
two sets of CCW Classic Track 18x12 18x305/30 and 18x13 18x335/30
or 18x315/30f & 18x345/35r
Now the DOWN side of wide rims and tires.
The car, when driven slow, under 80 mph or in a parking lot will handle like pig wallowing in the mud. No two ways around it.
I would never put tires over 305 on a street car again.
on the race track it handles like a train on rails
Peter
YES.
BBS is a good company too. But not BBS street rims, the BBS motorsports wheels. BIG difference
18" wheels on all four corners, forget the 19" or 20" wheels, just not customizable sized and they weight to darn much
Your body kit seems to be a lot like mine in width.
- Go with 19" rims all the way around (F) 19 x 11 and (R) 19 x 12. Tire combo should be 305/19/30 and 345/19/30. Both Michelin PS2 and Nitto Invo have nice tires.
You'll also probably need some coil-overs.
Yeah I have decided to just find a set of aftermarket wheels. I was given the idea to replace the control arms and associated parts from someone else who purchased the same kit as I have and it turns out his is sitting in a shed someplace un-driveable. So far I have only been able to find BBS, HRE, and CCW as manufacturers of a/m wheels that will basically extend the width of my front wheels by about 2", is this correct? Wouldn't a wheel with simply a wide lip accomplish the same thing?
No. You need custom off-sets that push the wheel away (out) to meet four fender lines. Keep in mind that if you change your brake calipers to a larger size you could have clearance problems.
Thank you. I wasn't planning on changing the calipers, at least not in the near future. What size of an offset do you feel I should be looking for?
You need to do a little bit of measuring as each body kit is different. Get two straight line measuring sticks and measure from the flat spot where the rim mounts to the edge of the fender edge in both front and rear.
I then take those measurements and subtract a 1". Typically most rims "edge to edge" are 1" wider than the what there stated size is for the tire bead. Add in the 1/2" or so that the tire hangs over the bead and you should be close to flush.
Ideally, you should take a couple of blocks of wood and stick them under the "A" arms on one side and lower the car down on these blocks so that your suspension is not drooping when taking these measurements.
Thanks, the rear is fine and stock width/offset will be fine. It's only the front where I have to worry about a custom offset. I will try to get some measurements today, just to give you an idea here is what the car looks like
Based on your pictures, the easiest thing to do would be to get a straight edge and meausre from the center hub with wheels on to the inner fender liip.
Subtract a 1/2" and tell them you're using stock rims to base your measurement off of.
They can add the stock measurement plus the additional width to figure out the correct spacing..
Don't get a wider rim as you can't have larger tires in the front vs the rear.
That comes out to the measurements that AU N EGL gave above, 18x11 front and 18x13 rear .. I will search the forum, maybe I'll get lucky and someone will have a set for sale
You cannot get 13" rims under stock fenders in the rear.
You cannot run bigger tires in the front than the rear with out causing all kinds of abs and active handling problems.
18 x 11 rim does not mean ****, you need to know the off-sets.
You really don't seem to be that knowledgeable and I would take a few steps back before you throw a bunch of money down the toilet.
For the life of me I can't understand why you widen the front of the car but left the rear stock.
