splash guards/rock chips/appearance
Old Sep 4, 2009 | 07:47 PM
TOPKATTKG2's Avatar
TOPKATTKG2
Default splash guards/rock chips/appearance
would like your thoughts on splash guards, i normally do not like the looks of them, especially on cars like ours, but my 99 has 60k, and has numerous rock chips, and the paint is beaten off pretty badly behind each tire. i would like to have those area re-painted, and possible color matched guards installed, but have seen very few vetts with these installed, and am just not sure i want them, do any of you have them and do they work, or am i better off to leave as is, thanks for your thoughts
Old Sep 4, 2009 | 08:04 PM
George V's Avatar
George V
I have these and like them
http://www.apsisusa.com/C5%20Corvett...le%20index.htm
Old Sep 4, 2009 | 08:52 PM
TOPKATTKG2's Avatar
TOPKATTKG2
Thanks for the info, I agree they look great, better than I thought they would, I will be ordering a set of these, thanks again topkattkg
Old Sep 4, 2009 | 10:03 PM
double-oh-coupe's Avatar
double-oh-coupe
Sounds like you've already made up your mind, but just for grins I thought I'd post what I installed.
Old Sep 10, 2009 | 08:53 AM
The Stranger's Avatar
The Stranger
Which ones did you install? They appear shorter in length.
Old Sep 10, 2009 | 09:32 PM
double-oh-coupe
I installed the C6 gaurds modified to fit the C5. Here are the instructions in case you or anyone else is interested.
http://forums.corvetteforum.com/c5-g...er-guards.html
Old Sep 10, 2009 | 10:16 PM
av8or's Avatar
av8or
Have you considered plastic (Cleartastic or 3M) protection? I bought the Cleartastic sheets three years ago...nearly invisible and they do a great job of protecting the paint in all the vulnerable areas (mirrors, wheel openings, in front of rear wheels, etc.) They're a bit of a pain to install, and must be removed to wax, but I find them preferable to traditional mud flap type protectors. One reason is that the area in front of the rear wheels wouldn't benefit much from mud flaps.
To splash guards/rock chips/appearance
