Is it the water pump?
Old Sep 8, 2009 | 08:38 PM
ABNVET.I's Avatar
ABNVET.I
Default Is it the water pump?
Ok I posted a while back about my car starting to heat up with a head and cam pack I just installed it is a maggie car and always before the head and cam ran about 190 or so. I had a hypertech thermo in it and run puple ice in the rad and the inner cooler. It has been tuned for the fans to kick on as they should. I check the fans and yes they are both running so I say maybe the thermo. Why did I think that because I never felt the lower rad hose get solid so it acted like the thermo didnt open. Replaced it same thing it never got solid. Could it be the pump?
Old Sep 8, 2009 | 08:43 PM
lucky131969's Avatar
lucky131969
Only soo many possibilities here. If you've replace the thermostat, and you still don't have circulation, it's probably the pump. Remove the belt, ,and turn it by hand to see how it feels.
Old Sep 8, 2009 | 10:04 PM
ABNVET.I's Avatar
ABNVET.I
Just took the Hypertech thermostat that I replaced and tested it in a boiling pan of water it opened as it should. I think the only thing left now is the pump
Old Sep 8, 2009 | 10:15 PM
vsocks1's Avatar
vsocks1
I have a stock 10,000 mile waterpump out of my 03 Z06 for sale. I replaced it with a Meziere EWP!
Let me know if you are interested.
Old Sep 8, 2009 | 10:16 PM
4DRUSH's Avatar
4DRUSH
I have a 2 year old (2004 version) Water pump with less than 5k miles sitting around doing nothing. I can ship it to you for $60.
Old Sep 8, 2009 | 10:42 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Do you have a underdrive harmonic balancer? Water pump is a pretty simple device. Not much to go wrong except for bearing and seal. I'd be looking for other things.
Old Sep 8, 2009 | 11:31 PM
ABNVET.I's Avatar
ABNVET.I
Nope no under drive on it the maggie didnt like that. Im with you why didnt it circulate it is almost like the fins arent spinning. You can look in the over flow and never see the water circulating. As if it never reaches the bottom hose.
Old Sep 8, 2009 | 11:44 PM
byronhunter's Avatar
byronhunter
Whoa, you won't feel the bottom hose get "solid" if the pump is pumping. It feeds the pump, therefore when you rev the engine, that is the vacuum side of the pump. Have I got this right? If not I'm going to turn this thing off and go to bed! Bring it on!
Old Sep 9, 2009 | 12:07 AM
lucky131969
Rather than checking for a solid hose....you should be feeling for heat, indicating circulation.
Old Sep 9, 2009 | 05:23 AM
vettenuts's Avatar
vettenuts
Since you just did heads, what gaskets and were the coolant passages lined up on the gaskets to the block? The coolant goes into the front of the block to the rear and then up into the heads and back out the front. If the gasket is backwards the coolant will go into the block and then immediately out and hardly any circulation will take place.
Old Sep 9, 2009 | 09:49 AM
lucky131969
Good point..
Old Sep 9, 2009 | 11:18 AM
ABNVET.I's Avatar
ABNVET.I
Originally Posted by lucky131969
Good point..
Thought of that and made sure to double check the gaskets when the heads went back on. So Im almost certain that wasnt it. I remember taking one head off to double check before I bolted them down.
Old Sep 9, 2009 | 11:19 AM
ABNVET.I's Avatar
ABNVET.I
So the lower hose never gets solid? Man am I old school
Old Sep 9, 2009 | 11:20 AM
lucky131969
They do, be it takes time and temperature, and subsequently pressure, before you will get that result.
Old Sep 9, 2009 | 11:39 AM
wcsinx's Avatar
wcsinx
Prob. a stupid question, but is your radiator clean? Mine looked fine, but when I blasted it with an air wand I got a pretty decent pile of sand and grass out of it.
Old Sep 9, 2009 | 11:50 AM
ABNVET.I's Avatar
ABNVET.I
Yep air cleaned it before I put it back in and only have maybe 400 miles on it now at 230 temp. That is why I havent drove it much. Another thing is if I keep it around 55-60 mph it stays about 200 but any thing over that the temp rises pretty fast slow down it goes down.
Old Sep 9, 2009 | 11:54 AM
lucky131969
What procedure did you use when refilling the system? Are you positive you have all the air out?
To Is it the water pump?
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
always before the head and cam ran about 190 or so. Could it be the pump?
I seriously doubt that the water pump is your problem. They generally fail due to either the mechanical shaft seal leaking, or the shaft bearing becoming loose or noisy. It's very unlikely that the pump impeller is not working, unless it's turning in the wrong direction.
I've found that it's usually the last thing done, that created the new problem.
Old Sep 9, 2009 | 11:59 AM
ABNVET.I's Avatar
ABNVET.I
I cahnged thermos last night so drianed a lot out of the system. When I refilled the rad I jacked up the passanger side to have the air go to the res tank and filled it slow with the motor running. So to be honest not sure if the air is all out. I called a shop and they told me they want 130.00 to put the tool on there to purge the air. Isnt that a little high? I can get one of them tools off fleabay for that.
Old Sep 9, 2009 | 12:15 PM
wcsinx's Avatar
wcsinx
The air is going to work out of the system normally regardless. It sounds like you've done quite a bit of driving in this state, so as long as you kept the reservoir topped off I can't imagine you still have air in the system.
Does the heater blow hot? Is there any change if you run with pure water?
With everything you've eliminated, it's starting to sound like you've got a blockage somewhere ... either air or coolant.
