Is it the water pump?
Good luck
Good luck
Good luck
I'm not saying you're mistaken btw. Just curious to know if I did something wrong or just got lucky.
Good luck
Fill the cooling system through the surge tank.
Fill the cooling system with a 50/50 mixture of DEX-COOL® coolant and deionized water.
Start the engine.
Allow the engine to idle for 1 minute.
Install surge tank cap.
Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant temperature reaches 99°C (210°F).
Shut off the engine.
Remove the surge tank cap.
Start the engine.
Allow the engine to Idle for 1 minute. Fill the surge tank to 12.7 mm (0.5 in) above the COLD FULL mark on the surge tank.
Install the surge tank cap.
Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant reaches 99°C (210°F).
Top off the coolant as necessary, 12.7 mm (0.5 in) above FULL COLD mark on the surge tank.
Rinse away any excess coolant from the engine and the engine compartment.
Inspect the concentration of the engine coolant.
His avatar would suggest otherwise assuming that's his car. Fill the cooling system through the surge tank.
Start the engine.
Start the engine.
The hard way.
Well drained the rad again and followed the steps to filling it so you dont get air in the system. Took it for a test drive and it all seemed good. But the morning was a cool 76 degrees. Went down to a friend of mine to pressure test the system and he didnt have time he said take it out on I 55 and see it the temp hold. When I got on the interstate thats when it happened. I punched it to get off the ramp and out the back I see a large cloud of whit smoke. I just new I blew a head gasket. I hit the first U turn I could find and limped it back to a station off the highway. Opened the hood and there was anti freeze all over the place and my belt was shredding. But I couldn’t see anything wrong. I bought a gal of Ant Freeze put it in and limped it back with a loose rad over flow cap to my friends station. Opened the hood and he looked down to see a hose lying loose. Turns out it was the hose from the intake coolant line to the TB. Seems that if the clamp was there it wasn’t tightened so it never pressurized and it would be sucking air. Since I haven’t drove it much since the install it never had a chance to pop off I had noticed a little ant freeze on the garage floor from time to time but thought it was from the water pump going bad. Put a new belt and hose clamp on cleaned it for 3 hours and now it never goes above 223 degrees. What a relief was thinking maybe I did put the head gaskets on wrong after all. Thanks for all the input
