Power Door Lock Issue (Help)
Old Sep 4, 2009 | 09:25 PM
Dutzman's Avatar
Dutzman
2nd Gear
Default Power Door Lock Issue (Help)
A friend of mine has 98 C5 with the factory alarm system. He arms the remote and the car locks normal but a few minutes later it unlocks on its own then locks again. He tried purchasing a new remote from the dealer but that didn't do anything. Has anyone had this problem before?
Old Sep 4, 2009 | 10:33 PM
mcomte's Avatar
mcomte
does it do this everytime? how long does it take for it to lock and unlock after the initial lock? If it were me I would roll down the window and run the tech 2 thru to the dlc and look at the bcm inputs after i locked the doors with the remote. see if there are any crazy inputs before it starts doing the phantom unlock/lock.. good luck.
Old Sep 5, 2009 | 12:35 PM
Dutzman's Avatar
Dutzman
2nd Gear
It starts acting up a few minutes after he locks the car then it will just unlock and lock the doors manually. Is this a sign of a bad body control module? Trying to figure this out before spending a fortune at the dealer.
Old Sep 5, 2009 | 01:33 PM
feeder82's Avatar
feeder82
do a search lots of answers for this problem
http://forums.corvetteforum.com/c5-g...w-problem.html
Old Sep 6, 2009 | 02:18 PM
bluvette79's Avatar
bluvette79
i guess it is too simple to ask if your passive lock switch is on/or malfunctioning but i will ask anyway. i can only do simple!
To Power Door Lock Issue (Help)
