Lost my pivot cup please help!
Old Sep 5, 2009 | 02:54 PM
canar's Avatar
canar
Default Lost my pivot cup please help!
I had a friend put on my B&M shifter for me. Long story short the bolts came out while I ws driving. The shifter came off and the pivot cup on the bottom of the shifter popped off and must have fallen on the road. I just spent the last few hours trying to locate one at a dealer to no avail. DO aftermarket ones exist? What can I do?
Ted
Old Sep 5, 2009 | 03:10 PM
hotwheels57's Avatar
hotwheels57
The billet based B&M shifter requires 1/4" longer bolts (torqued to spec) than the stamped steel oem shifter. That's probably why they came loose and the shifter fell off...
No oem or after market replacement part is available. Maybe from a salvage yard.
From what I understand, MGW shifters don't use them because they were designed to eliminate them. You might find someone who has installed an MGW shifter who no longer needs the plastic bushing.
Old Sep 5, 2009 | 04:54 PM
TEXHAWK0's Avatar
TEXHAWK0
You have to buy the whole shifter assembly from GM.
Are you sure the bushing is not still in the tunnel somewhere?
Unless the shifter came completely out of the base, I am surprised that the bushing could get out of the lower housing. I am also surprised you could not tell the shifter was getting loose before it came completely off.
Old Sep 5, 2009 | 05:16 PM
canar's Avatar
canar
It actually gets even more bizzare. I was not even shifting hard when it happened. I shift pretty hard often too. I was just moving between 2-3 and the whole stick came off in my hand. I am sure it fell down the side.
And yes the person that installed it did not use long enough screws you are correct. Buying the whole GM assembly costs more than the MGW shifer. Lucky me huh?
Old Sep 5, 2009 | 08:02 PM
mischiefse7en's Avatar
mischiefse7en
does the stock shifter have a cup on it?
Old Sep 5, 2009 | 09:11 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If I were you I would get a mirror and a flashlight and look inside the tunnel area. Its probably just sitting there on the tunnel plate.
Bet ya!
BC
Old Sep 5, 2009 | 09:54 PM
LoneStarFRC's Avatar
LoneStarFRC
Bet ya!
BC
Totally. Especially if it had any grease/lube on it and it's "stuck" to the tunnel plate.
Old Sep 5, 2009 | 11:03 PM
canar's Avatar
canar
Can I do that from the top? I really have no good way to jack it up high enough to fit under it.
Old Sep 5, 2009 | 11:35 PM
LoneStarFRC
Yep. Remove the shifter and the base from the torque tube if necessary. Get an inspection mirror, preferably one that extends and has a pivot head and a flashlight and look for it. The tunnel plate is nice and flat and there is an open space only at the very front and the very back. The rear opening is approx 1 foot or more from where the shifter is.
Go look for it and remember, it's plastic so a magnetic retriever won't "grab" it.
Old Sep 5, 2009 | 11:57 PM
canar's Avatar
canar
Even if I do see it with the mirror how would I get it out?
Old Sep 6, 2009 | 12:14 AM
LoneStarFRC
Ummm, do you know what a coat hanger is?
Old Sep 6, 2009 | 01:16 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Gum on a stick. Flexible mechanical fingers. Air and blow it out the back. Or send me $19.95 and I'll pop the one off the stock factory C5 shifter I have laying around some place. Or maybe I'm just full of crap on the $19.95 and would settle for whatevers fair including shipping.
Old Sep 6, 2009 | 01:09 PM
canar's Avatar
canar
PM Sent
Old Sep 6, 2009 | 01:55 PM
lionelhutz's Avatar
lionelhutz
I was going to post that. Blow compressed air down around the torque tube at all different angles and see if it falls out onto the ground.
I was also going to post that I installed a MGW so mine is just lying around here too open to offers. Lots of people here have them lying around.
Peter
Old Sep 6, 2009 | 01:57 PM
LoneStarFRC
PM Sent
Did ya find it?
Old Sep 6, 2009 | 02:20 PM
canar's Avatar
canar
Originally Posted by LoneStarFRC
Did ya find it?
Nope did not see it
Old Sep 6, 2009 | 06:26 PM
canar's Avatar
canar
Whoever can get me one quick. I PM'd the first person but no reply yet. I am sure they will. I hate having the car down over something like this..
To Lost my pivot cup please help!
Old Sep 6, 2009 | 10:02 PM
mischiefse7en
i have an OEM shifter also i can send you tuesday....
Old Sep 7, 2009 | 11:35 PM
Camjamsdad's Avatar
Camjamsdad
St. Jude Donor '13
Hmm I answered the PM and posted in this thread earlier today. In any event shoot me your address via PM and I'll get it out to you for the cost of shipping. The crack about $19.95 was just pulling your leg.
Keep your eye on your mail box in a couple days.
Old Sep 9, 2009 | 10:59 AM
canar's Avatar
canar
Thanks a ton for helping me with this I really appreciate it. Hopefully I will be able to pay this forward to anyone in need of help in the future on here.
Ted
