MAF check
Old Sep 7, 2009 | 06:40 PM
Blow Torch's Avatar
Blow Torch
Default MAF check
Is there any way to check a MAF to see if it's bad? What symptoms did any of you have that changed their MAF from the 75mm to the z06 85mm?
I had a Z06 MAF that came with my procahrger kit, that I swapped in before going for it's last dyno tune, and I absolutly can't get it to run below 2000 rpm, and the afr indicates an extremely rich mixture even after some changes in MAF table.
Bottom line, do I have a bad MAF, or just need more tuning?
