Active Handling Issue
Old Sep 10, 2009 | 01:14 AM
Gearbanging101's Avatar
Gearbanging101
Default Active Handling Issue
I know there are a ton of threads about active handling but none of them fit my problem. I have a 2001 Coupe and within the past week the Active Handling will engage at random times. I can feel the brakes slightly grab and it will disable Cruise Control if I am using it. Also, if I happen to be applying the brakes during the time I can feel the pedal pulsate.
I have not found a specific pattern to when it engages: any RPM, smooth roads, rough roads, turning, going straight, speeding up or slowing down. It does seem to only happen as speeds in excess of 40MPH.
Reading the forums suggest the following:
Check for codes- No codes relating to steering, suspension, or body.
Bad alignment- The car was aligned about 6 months ago. The tires are wearing evenly and does not pull to one side.
Anyone have any suggestions to help diagnose this issue?
Old Sep 10, 2009 | 10:26 AM
87SAM's Avatar
87SAM
Here's a thread which discusses the same issue.
http://forums.corvetteforum.com/c5-t...-no-codes.html
Old Sep 10, 2009 | 12:02 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You have one or more of the following issues:
- Yaw Rate Accelerometer bad
- Lateral Rate Accelerometer bad
- Steering Wheel Position Sensor (SWPS)
- Wiring/connector issue with the above sensors.
- EBTCM bad (***NOTE! The EBTCM repair places can NOT repair this type of EBTCM failure.) Its a problem with the microprocessor in the EBTCM which can not be fixed.
Get a service manual and start checking the sensor outputs. My first guess is the SWPS is defective but,,,,I would investigate first. I hate throwing money/parts at a problem.
BC
Old Sep 10, 2009 | 02:03 PM
Gearbanging101
How did I miss that one in my search!!?? Thanks.
To Active Handling Issue
