Oil Pressure observations
Old Sep 12, 2009 | 11:43 AM
8VETTE7's Avatar
8VETTE7
Default Oil Pressure observations
Old Sep 12, 2009 | 11:59 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Originally Posted by 8VETTE7
I just returned from a trip back east and while driving in the flatter parts of Ok, Tx, Nm, and Az I noticed something I am at a a loss to explain/understand. Since the roads were pretty flat and reasonably straight I would set the cruise at about 83 and with nothing to do but steer around the vehicles you come up on I had plenty of time to play with the gages. I noticed a strange fluctuation pattern of the digital oil pressure readings. High would be 44 lbs but then the pressure would drop to 43, then 42, then 41 then 40 and then suddenly go back to 44. The cycle took about 50 minutes to repeat and did so for hours at a time. Anyone got any ideas other than just another crappy piece of GM equipment????
Wow, a gauge that has less than a 2% variance and it is labeled crappy??? That's pretty good by most any standard. The difference you are seeing could be cause by a number of things. My guess would be voltage or oil temp. Were you using A/C?
Old Sep 12, 2009 | 12:31 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Its probably just the sensor having issues.
Old Sep 12, 2009 | 03:34 PM
Rob's 73's Avatar
Rob's 73
I noticed that in my wife's 08. I would bet it is the oil pump's pressure relief valve opening and closing slightly. You are probably seeing a very accurate gauge.
Old Sep 12, 2009 | 04:52 PM
Eric D's Avatar
Eric D
I think you missed the point. Drop incrementally in 1 lb increments then jump up four and repeat. Not a sequence that makes a lot of sense. Yes I had the AC on at times and I also ran with the windows open at times (when it wasn't raining). Didn't make any difference as far as I could tell.
Maybe I did miss your point and I'm not sure yet. Maybe I focused on the comment of "another crappy piece of GM equipment" too hard. I guess I started wondering what other GM equipment you feel is crap, not including the column lock issues,we all know that is without a doubt crap!
To Oil Pressure observations
