Ring and pinion change
Old Sep 14, 2009 | 02:57 AM
Purple Corvette Jim's Avatar
Purple Corvette Jim
Default Ring and pinion change
Is it possible to get a new ring and pinion gear change without changing the complete carrier. DTE want $1800 for a new ring and pinion and reman carrier. Have a 2.73 and want to have a 3.15, but don't have $1800 for DTE.
Old Sep 14, 2009 | 11:28 AM
corvettebob1's Avatar
corvettebob1
Look in the C5 parts for sale section and pick up a complete diff for around $600.00
Old Sep 14, 2009 | 04:53 PM
Purple Corvette Jim
I only have 33,000 on mine, when I buy a complete used dif, I don't know what I will be getting. Is it possible or does anyone know where I can get a new ring and pinion and installed without having to buy the whole thing
I think mine is in good shape !
But I will look in the "parts for sale" section.
Old Sep 15, 2009 | 01:19 AM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Sorry, but unless you really know what you're doing (and even then), you're out of luck.
Problem is you have a 2 series carrier, and a 3 series gearset won't fit in there properly. You'll need a thicker gearset for it to work. For F-bodies, they have spacers that are made for just such a conversion (or thick gears), but I've never seen them for C5's. Even sites that are dedicated to gear and pinions don't list a thick gearset for the C5.
I have seen that DTE has built 2 series cases with 3.15's and up. You'd have to contact them to see if it's worth it. $1800 sounds really high, are you sure you weren't comparing to a stage x built diff?
It's much easier to get a fully completed pumpkin from a 6 speed car (3.42) and be done with it, even if it is used.
Old Sep 15, 2009 | 07:26 AM
KBlanke's Avatar
KBlanke
Definitely much easier to swap the whole pumpkin. You have to know what you are doing and have the right tools to swap out the gears. We have a guy that builds ours for us in with different gears and then just swap the pumpkin depending on what track we are running at.
Old Sep 15, 2009 | 07:57 AM
1badf350's Avatar
1badf350
You can pick up a used 3.15 complete rear for about $300 in the for sale section. 3.42 complete rears go for about $600-$700.
To Ring and pinion change
