How do I fix these codes/problems?
Old Sep 14, 2009 | 08:38 PM
Z0SEX's Avatar
Z0SEX
Default How do I fix these codes/problems?
C5 2003 Z06
I have the following codes:
TCS C1232 - LF Wheel Speed Circuit Open or Shorted
BCM B2252 - ??
A0-LDCM B2252 - Key Cylinder Switch Fault
A1-RDCM B2265 - Horizontal Position Sensor Fault
Following noticeable problems:
The past day my controls on the driver side door have stopped working (window button; seat positioning button; locks, etc)
I already know what most of the codes are, so how do I go about fixing them. I searched the forums but every post seems to just say what it is, not how to fix it.
Thanks,
Colt
Old Sep 15, 2009 | 04:34 PM
Z0SEX's Avatar
Z0SEX
does anyone have any suggestions?
Old Sep 15, 2009 | 04:37 PM
lucky131969's Avatar
lucky131969
Originally Posted by Z0SEX
C5 2003 Z06
BCM B2252 - ??
Thanks,
Colt
You don't mention if they are current or history codes. With regards to the left door controls, start with examining the wiring in the left accordian tube.
Old Sep 15, 2009 | 10:02 PM
Z0SEX's Avatar
Z0SEX
TCS C1232 is a history but I have cleared it several times in the past couple of weeks; it keeps returning.
BCM B2252, A0-LDCM B2252, A1-RDCM B2265 have yet to return. I was not sure if the two door control mod. codes would have anything to do with my problem. I will check the accordion tube; it does seem to be a connection problem due to the fact it works after I open the door or keep pressing a few times.
Thanks for the help though!
Old Sep 15, 2009 | 10:04 PM
lucky131969
Inspect the harness and connectors to the wheel sensor. Common problem. Good info in the electrical sticky on this.
Old Sep 15, 2009 | 10:06 PM
Z0SEX's Avatar
Z0SEX
Alright thanks; I will check out the sticky you referred also.
Old Sep 15, 2009 | 11:34 PM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
BTW, here's the sticky:
http://forums.corvetteforum.com/c5-t...n-long-39.html
Old Sep 16, 2009 | 12:45 AM
Z0SEX's Avatar
Z0SEX
I read up on both my problems with the TCS code and my door controls. I am gonna check the wheel sensor harness tomorrow and also check for bare wires in the accordion.
thanks for all the help!
PS:will update tomorrow
To How do I fix these codes/problems?
