I HAVE HAD THIS PROBLEM WHERE IF I DONT DRIVE IN 1-2 DAYS BATTERY IS DEAD BRAND NEW OPTIMA RED TOP GAGES SHOE ALT IS CHARGING DRAINS OVERNIGHT 2 BATTERY I ALSO CHARGE OVERNIGHT TRYING TO SAVE MONEY BEFORE I USE MY EXTENED WARRANTY 2004 C5
Originally Posted by epti88
who cares about the caps grow up and answer the question have fun moronsanswer solved
a common problem is that the front seat adjuster system will go bonkers and will stay ON all the time---even with engine not running or key off--i just set my seat and unplugged the pigtail--Check to see if the trunk area lites are going off as well as the indoor vanity mirror lites--Also if you havw an aftermarket stereo-make sure that it is being feed by a "swithcted " wire-- and is not powered up all the time--
