97 evap question?
Old Sep 15, 2009 | 02:16 PM
TurboBerserker's Avatar
TurboBerserker
Default 97 evap question?
My corvette came with a blown ls2 and had serious issues with wiring routing, hose routing (had 2 PCVs routed to each other, etc).
EVAP purge vac switch:
He had the the evap purge vacuum switch (see pic) teed off the same line as the FPR. I hooked my FPR to vacuum and kept this module teed into that line. Now, I'm getting some random misfiring and sloppy idle at times. I'm wondering if this should be left open to atmosphere?
Hose routing diagram:
That diagram is about as useful as a wrench made of wet cardboard, but I don't see a second line going to the switch (and I don't see #7 connecting to anything but the FPR). Anyone know for certain?
Old Sep 15, 2009 | 09:37 PM
TurboBerserker
Anyone snap me a picture from a 97 or 98?
Old Sep 16, 2009 | 12:38 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The OEM FPR connects to a fitting on the AIR BRIDGE! I had a 98 and remember it. I plugged mine with a small rubber plug!
I purchased a FPR improvement kit from ECKLERS that rerouted it to the PCV port. They claimed that the re-rout would lean a factory rich C5 for better performance. Did it help?? Who knows?? I never dynoed it or data logged it.
That would be my recommendation. Do some EFI Live or HP Tuners data logging and see if its running RICH or LEAN.
Bc
Old Sep 16, 2009 | 09:20 AM
TurboBerserker
Running a stock 97/98 FPR to a vacuum source will allow you to set your IFRs to a single number (43 in my case) and the vacuum draw on the FPR will adjust your fuel pressure at the rails.
The way the factory has it set up, it is essentially mimicking a non-vacuum referenced FPR like in the returnless systems. In later years, GM abandoned this practice in favor of drawing a vacuum and letting the FPR do it's job. It's much easier to tune this way, no IFR tuning needed. I've done the OLSD and OLMAF tuning on the car already (and am debating just leaving it in OLMAF mode).
My main question is on the EVAP vacuum switch? Anyone know if the "extra" vacuum nipple is vented to air?
Old Sep 30, 2009 | 07:14 PM
TurboBerserker
Update: I pulled the extra line off (so the vacuum switch has a port to atmosphere) and it ran better so I left it off...
To 97 evap question?
