A leaking differential cover on the C5 is pretty common - I believe there is a GM TSB on this problem. Switching to Redline fluid and seeing these drops are a coincidence. I use the same fluid in my differential and engine - no problems just great performance.
So it wasnt diff fluid after all. The guy who installed my stainless steel brake line didnt tighten the rear right line. The fluid would leak onto the leaf spring, travel down toward the center of the car, then drip. It would strip some of the dirt off of the leaf spring, giving it a weird color, that led me to believe that it was diff fluid.
