1998 Heater Problem
Old Sep 20, 2009 | 04:16 PM
jackb2's Avatar
jackb2
7th Gear
Default 1998 Heater Problem
Hi,I recently purchased a 1998 convertible with the dual zone climate control system.The problem is I cannot get heat to blow out (just cold air)on the driver's side,in any mode-floor, dash vents or defroster.I tried to see if I could see a problem under the dash as far as maybe a duct door not opening or closing but nothing was really visible.Passenger side is fine and when operating the A.C. it's fine on both sides.Also,everything lights up fine on the control panel and on both sides the temp. numbers will increase and decrease fine with both control *****.Also,there are no codes stored.Has anyone run into this problem before?Thanks very much for any tips.
Old Sep 20, 2009 | 05:02 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Jack
Read and post your DTCs. The air damper is controlled by a servo motor. If its bad or not working correctly, it will throw a DTC. Sometimes just clearing the DTC will cause it to work properly again. Turn the HVAC Control to OFF. Then pull up the DTCs write the info down and post up what you find. Then clear any DTC that you have.
Once you clear the DTC,,,you will hear the servo motor cycle and test its self out. You may need to do this procedure several times to get it to sync up properly.
Give that a try.
Bill
Old Sep 20, 2009 | 05:03 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
READING YOUR Engine Diagnostic Codes (DTCs)
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open etc…)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes)
If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, C or ;H. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present;
press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET
To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
Here is very good site of DTC definitions:
http://www.gearchatter.com
Make sure to include the H or C suffix!!
Old Sep 22, 2009 | 12:35 AM
jackb2's Avatar
jackb2
7th Gear
Default RE 1998 heater problem (Bill)
Bill,thank you very much for your help.I had a Snap-on scanner on it and the only code was a BCM History code B2723,Passenger Key Detection Circuit Open/Short but I don't see how that would apply.I will try what you said about getting codes from the dash when I get a chance and re-post.I didn't even realize you could get a HVAC code,that doesn't even come up on the scanner-just eng./trans./antilock/BCM codes.Thanks again.
To 1998 Heater Problem
