got these codes
Old Sep 17, 2009 | 09:07 AM
george watson's Avatar
george watson
Default got these codes
Plus check engine light....
10-PCM P1035 C P0140 H C P0155 C P0161 C
80-LDCM U1064 H
A1-RDCM U1064 H
A6-SCM U1064 H
Wha't going on?
Old Sep 17, 2009 | 10:37 AM
87SAM's Avatar
87SAM
First, you could have the PCM numbers inverted. Guessing they are P01XX.
The P0135, 55 & 61 says your HO2S are not heating up.
The P0140 says the HO2S was out of range (probably because the heater went out).
A easy place to start is to check heater fuse 15 in the under hood fuse block.
