Hello vettewrench i was given your name by another member because i bought white face indiglo guages and have to hook them up to the back of my dash cluster to the wire that is hooked to turn on the lights when parking lights come on, would you know which color it is? Thanks alot! :confused:
I sent a link to Brian on this post.He should get back to you ASAP.He pulled an all-nighter working on a customers car,dedication:cool: ,so he's out-cold right now!!! :D :D :D :
I sent a link to Brian on this post.He should get back to you ASAP.He pulledd an all-nighter working on a customers car,dedication:cool: ,so he's out-cold right now!!! :D :D :D :
Someone with a faster car then yours!!!!!!!! :p: :p: :p: :p: :p: :p: :p: :p:
Pretty funny coming from a guy who has an "All Show and No GO!" car that's been sitting on a lift for the past few months :p: :D :p:
[Modified by O-Ace, 3:50 PM 2/22/2002]
Trust me when it is done you will be soooo far behind you will not even be able to see my taillights little boy!!!!!!!!!!!
Not only is your car "All Show", you're "All Talk". You two were made for each other :hat :p: :D
All you Chicago guys are slow!! :D Especially when you involve corners! :jester
[Modified by MattG, 5:19 PM 2/22/2002]
You're right....we should move to Canada. Instantly, I could afford more mods considering my dollar will be multipled by 239849348 when I go to Canada :p: :D
Very true, but unfortunately driver skill does not get multiplied by that ratio :)
I found the power connection for the indiglo gauges, it's the green wire going to the dimmer on the instrument panel, you can connect the ground to anything metal behind the dash. you will also want to disconnect the power cable to the black lights in the instrument panel, this will make the indiglo look better. :cheers:
RPOZ47 Thanks alot for your help i appreciate it. Now i can finally get these damn things in,lol. Even my chevy dealer in the area was to ignorrant to tell me the answer but thanks again. :cheers:
O-Ace and Slammed Vette. You two are talking a lot of crap, so I guess that when I come over there next weekend you are going to line them up?! Can't wait to see your cars, slow as they may be! :D :cheers: :chevy
