I need better wheel studs for my C5!
Old Sep 18, 2009 | 09:44 PM
Ksths2's Avatar
Ksths2
Default I need better wheel studs for my C5!
I've been swapping my street wheels for my ET streets and the wheel studs are not happy with it. I always have put anti-seize on the studs and been really careful not to strip the thread but they are not meant to have the wheels swapped a milliion times and the threads are not good.
Anyone know where to get better M12x1.5 wheel studs to replace the stockers? Or what are other drag racers doing????
Old Sep 18, 2009 | 09:45 PM
AU N EGL's Avatar
AU N EGL
Look up ARP Studs
Old Sep 19, 2009 | 12:49 AM
MTPZ06's Avatar
MTPZ06
Originally Posted by AU N EGL
Look up ARP Studs
ARP has a reputation second to none for engine/exhaust bolts & studs, as well as wheel studs.
Old Oct 1, 2009 | 08:53 PM
Ksths2's Avatar
Ksths2
yeah ARP has good stuff for sure, i just wanted to see if you guys were using something else. i'd rather do it the right way first
Anyone know are the stock ones pull through type? (splined where they mate w/ rotor?)
Old Oct 1, 2009 | 09:39 PM
OleStraightStick's Avatar
OleStraightStick
St. Jude Donor '08
yes the stock ones are splined.. and they are fun to remove
Old Oct 1, 2009 | 10:02 PM
Ksths2's Avatar
Ksths2
i bet! i'm assuming i have to take the rear disk off to replace these studs correct?
Old Oct 1, 2009 | 10:39 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
There is a write up "somewhere" that tells of drilling a hole in the back plate and knocking them through. I've done it this way on the rear, it works. I threaded the old nut onto the stud a little ways, and tapped it out. Looking at the wheel, I drilled the hole around the 2 O' clock position. If I remember correctly, I used a half inch bit, and reamed it a little
Old Oct 1, 2009 | 10:51 PM
waddisme's Avatar
waddisme
I swap mine about once a month for track pads and rotors. I have a die I got from the hdwe store I use. I run them over the threads to keep them clean. David Farmer mentioned one time that small pieces of metal get in the threads and chew them up. Also, be careful not to over torque when installing. So far so good. About the ARP studs, they are longer than stock, so unless you have open lug nuts, that could be an issue. Good luck whichever route you choose.
Old Oct 11, 2009 | 09:20 PM
Ksths2's Avatar
Ksths2
Drilling out the backing plate is a great idea, i just bought a 34mm socket and broke loose the nuts but still can't get the hub that the studs are pressed into off the car....... I'm assuming its just stuck right? i mean there is nothing else it looks like i need to remove to get off that hub is there?
Thanks for the ARP site info, i've got them on order.
Old Oct 12, 2009 | 01:52 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I purchased new studs from DRM. They have them longer then stock for special applications.
To I need better wheel studs for my C5!
By Michael S. Palmer | 2026-06-03 09:39:05
