Catalyst not ready
Evap System Not ready
Secondary Air Not ready
02 sensor Not ready.
The "not ready" is from where the inspection device is hooked into the cars port.
I want to get down to the bottom of this and find out if these have been disabled for some reason. I didnt build nor tune the car and personally would rather have a car thats compliant with the emission stuff but even before my build I had at least 3 codes and nobody knew why yet my car had all its emission stuff on it and didnt smell like a polluter..
more info, is the car modded, has it been tuned ect.
forged 402 ls2, ported fast 90/ported 90 tb, cnc stage 2 heads, 610 lift cam on 114 lsa, no cats, yella terras,2 bar map, sts twins running gt32s, built mn6, built diff with hardened half shafts, 9 lbs boost so far
Yea for all those mods that sounds about right for not ready status...
Catalyst not ready: you dont have cats
Evap System Not ready: doubtful you even have it on the car anymore
Secondary Air Not ready: doubt its on the car
02 sensor Not ready: rears are most likely taken out...
you can turn off the last 3 in tuner program and they wont even show up on a check and wont show not ready etc.
Catalyst im not sure if you can disable that in the tune or not..
