01 Z51 Sway Bars - Diameter
Old Sep 19, 2009 | 02:14 PM
jmbbluevette's Avatar
jmbbluevette
2010 SC GS Driver
St. Jude Donor '13,'17,'18,'19
Default 01 Z51 Sway Bars - Diameter
Are the diameters of the front and rear sway bars for a Z51 suspension in an '01 1 inch and 0.75 inch, respectively? Thanks.
Old Sep 19, 2009 | 03:32 PM
Last C5's Avatar
Last C5
Sways and Spring
Swaybars:
• C5 Base Suspension: 23 mm-front / 19.1 mm-rear / 3.81mm/2.0mm thickness
• C5 Z51 (97-99): 25.4 mm-front / 21.7 mm-rear
• C5 Z51 (00-04): 28.6 mm-front / 23.6 mm-rear / 4.15mm/3mm thickness
• C5 Z06: 30.0 mm-front / 23.6 mm-rear / 4.5mm/3.5mm thickness
• C6 Base: ?? mm-front / 22.0 mm (7/8")-rear
• C6 Z51: 31 mm-front / 25.4 mm (1")-rear
• C6 Z06: 31 mm-front / 28.8 mm-rear
• C5 Hotchkis: 31.75 mm-front / 25.4 mm-rear / 4mm/4mm thickness
• C5/C6 Addco: 32 mm-front / 25.4 mm-rear
• C5/C6 Addco: 35 mm-front / 25.4 mm-rear
• C5 Pfadt (Adjustables): 32 mm-front / 26 mm-rear http://www.pfadtracing.com/
• C5 Pfadt (Adjustables): 35 mm-front / 28.5 mm-rear (Pfatty)
• C5 T1 (GM Racing): 38.4 mm-front / 27.5 mm-rear / 6.35/6.35 thickness
• C6 T1 (GM Racing): 38.4 mm-front / 27.5 mm-rear / 6mm/?? thick
Springs:
• C5 Z06: 526# Front, 714# Rear
• C6 Z06: 531# Front, 782# Rear
• C6 Z51: 526# Front, 645# Rear
• T1 (C6): 582# Front, 850# Rear
• C6 Base: 420# Front, 657# Rear (VBP: 400-420 F / 600-620 R)
• T1 (C5): 582# Front, 793# Rear
• Pfadt Coil-overs: 425# Front, 575# Rear (Remember: Wheel rates!)
• Hyperco HPS (Street): 565# Front (12405HPS), #765 Rear (12406HPS)
• Hyperco HPT (Track/Solo): 625# Front (12407HPT), #850 Rear (12408HPT)
• VBP Sport 990# Front, 650# Rear
• VBP Extreme 1050# Front, 855# Rear
Old Sep 19, 2009 | 07:35 PM
jmbbluevette
2010 SC GS Driver
Thanks Last C5. Appreciated it.
To 01 Z51 Sway Bars - Diameter
