Changing out stat, need any advice.
Old Feb 21, 2002 | 03:30 PM
Blackjetvette97's Avatar
Blackjetvette97
Default Changing out stat, need any advice.
Hi all,
I ordered a 160 thermo and am going to put it in tonight. Are there any special procedures when putting it in that I should be aware of, like leaking coolant all over? I want to do the job right and have never changed one out in a vette. Thanks for any input!
Steve
Old Feb 21, 2002 | 03:44 PM
Stu in CA's Avatar
Stu in CA
Default Re: Changing out stat, need any advice. (Blackjetvette97)
Piece of cake with the o-ring vs a gasket design. You don't have to scrape old gasket material and risk damaging mating surfaces or worry about improper sealing of a gasket or use messy compounds. Just be sure to observe the relatively low torque spec for the fasteners, due to the alloy block, etc.
