Dead Starter (I think)
Old Sep 22, 2009 | 03:36 PM
tonyd414's Avatar
tonyd414
Default Dead Starter (I think)
Took out the vette no issues - left the gym and it was dead. Had to get it flat bedded back to the house.
When I try to start the car it make one click and nothing else. The battery seems to be fully charged (also tried to jump it) so I am thinking starter. I did a search and found a good post on checking some codes -will check that next.
So couple questions - will a code specifigcally tell me if I have a bad starter? If its a starter where you guys buying new one(AC Delco was $400) thought that was alot. Also anyone have a pic of where the starter is? I want to try to do the 'hit it' with a hammer to see if it will turn over.
Thanks guys/gals
Old Sep 22, 2009 | 03:48 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Passengerside, lower rear corner of engine. They're pretty easy to replace.
Old Sep 22, 2009 | 04:17 PM
lucky131969's Avatar
lucky131969
Thanks guys/gals
Hold off on changing expensive parts (and the Cro-magnon beating of the starter) until you have isolated the problem. Need to check for 12 volts at the solenoid when you try to start the car first. Also, a general inspection of all wiring at the starter.
Old Sep 23, 2009 | 11:14 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The solenoid is the electrical center of the car. Battery, alternator and starter all connect right there. Make sure that connection is clean and tight, not burned. When you attempt to start, make sure the security light on the IP Cluster is not flashing. When you turn the key to the start position, do you hear a click in the passenger footwell? Have you pulled your codes?
Old Sep 23, 2009 | 12:44 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Cro-magnon beating of the starter That made my day!
Manual or Auto car???????? I agree.
There are a significant number of things to check before you REPLACE a starter.
Ive owned a C5 since late 97 and worked on hundered of C5 and have NEVER seen a truely BAD starter motor.
Ive seen numerous bad solenoids and countless numbers of bad connections/improperly wired starters and burnt up connections on the starter solenoids but, ZERO bad starter motors. Im sure that there have been some on very high mileage C5. There pretty bullet proof.
The point Im trying to make is,,,figure out what is really wrong before you start with the BIG things. It might be something as simple as a loose battery cable or bad connection on the solenoid.
I have a schematic of the starting circuit at home (at work right now) and if no one post it before then, I will post it for you.
BC
Old Sep 23, 2009 | 01:04 PM
byronhunter's Avatar
byronhunter
Old Sep 24, 2009 | 10:41 AM
tonyd414's Avatar
tonyd414
This forum is awesome and the members are great.
I plan on trying all the suggestions this Sunday.
Is there an easy way to get access to the starter to check connections, etc. Should I jack the right side up / take the tire off? Anything else?
Old Sep 24, 2009 | 10:56 AM
lucky131969
Nope. Jack up the car, and get underneath..
Old Sep 24, 2009 | 11:35 AM
TRBO VNM's Avatar
TRBO VNM
sorry, little OT, but does anyone have a wiring diagram for the starter/soleniod? I see the diagram posted in this thread, but it isn't really giving me what I think I need.
I am trying to figure out which wires go on the larger lugs of the soleniod. one side has a braided wire on it that goes into the starter. the other side does not. the side without the braided wire gets the larger red cable. the large black cable is block ground along with a smaller wire.
I know the smaller ring terminaly goes to the small lug on the soleniod.
then I have 2 wires that appear to have fuseable links. both start out as red, one larger than the other. the smaller one turns to a black wire after the fuseable link. the larger red wire turns to more of an orange color after the link. just trying to figure out which lugs these 2 wires go on. I have searched, but nothing is coming up that is this specific.
from the schematic above it looks like the lug with the large red wire from the battery gets an additional wire and so then the other lug with the braided wire going into the starter gets the other wire. just not sure which goes where.
any help is appreciated
Old Sep 24, 2009 | 11:44 AM
dgrant3830's Avatar
dgrant3830
Bill has some great close-up pictures of the solenoid connections for you in the electrical sticky above. Do not forget that if the battery is connected above, the solenoid connections are electrically HOT! You can and will, weld your wrench to the frame, motor or whatever it touchs and possibly explode the battery. So please disconnect your battery's negative terminal first before working on things down there.
Old Sep 24, 2009 | 12:26 PM
TRBO VNM's Avatar
TRBO VNM
thanks. yeah, battery has been disconnected. I saw one pic in that thread and it appears both fuseable links and the large red go to the same lug. not sure why I thought the other lug had another wire on it.
thanks
Old Sep 27, 2009 | 06:16 PM
tonyd414's Avatar
tonyd414
1999 C5 A4
Pulled the codes this weekend here is what is flashing:
28-TCS = C12255 H
58-SDM = B1001 H
A0-LDCM = B2252 H / B2283 H / B2284 H / U1255 H / U1064 H / U1016 H / U1096 H
A1-RDCM = B2253 H / B2283 H / B2285 H / U1255 H / U1064 H / U1016 H / U1096 H
B0-RFA = U1096 H / U10164 H / U1016 H / C2100 H / C2120 H
Ok - who can tell me what is going on
Old Sep 27, 2009 | 07:13 PM
byronhunter
tonyd414, do you have a voltmeter, and are you able to read the Schematic above?
Old Sep 27, 2009 | 07:59 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old Sep 27, 2009 | 08:11 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your getting a LOT of U series DTC's Disassemble the rubber accordion tubes between each door and disconnect the door connectors and see if there are any changes in the symptoms. If the serial buss is having issues, it can cause the car not to start. Been there!
BC
Old Sep 29, 2009 | 06:46 PM
tonyd414's Avatar
tonyd414
OK - tried all the suggesions - got no place fast.
Had it towed to my garage - new starter installed and working again.
$450 out the door (GM starter) - so more than I wanted to spend but happy to get my car back
Old Sep 29, 2009 | 09:27 PM
rebelheart's Avatar
rebelheart
Now you have to ask yourself,"did the starter fix it,or did they repair the bad connection at the starter solenoid when they replaced the starter?"
To Dead Starter (I think)
Old Sep 29, 2009 | 09:36 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
My thoughts EXACTLY! You would ba amazed at how many times this happens.
BC
Old Oct 1, 2009 | 10:43 AM
rebelheart's Avatar
rebelheart
Agreed!
Old Oct 1, 2009 | 10:47 AM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
I had a battery cable work loose once. It acted the same way. I tightened it in the parking lot, and went on my way. I doubt it was really the starter.
