Brake line around the axle 3 times now...
Hey guys. I have a 2000 coupe that has have some issues with the brake line wrapping around the rear axle. The first time it did it I was doing aprox 130 and all of a sudden I hear a click click click... Pull into the paddock and find the rear brake line had wrapped around the rear axle. So we get the car home and fab up a new line (cannot buy them pre bent). We had it pretty much the same as the stock line. Next time out, around 130mph click click clicc.... pull in and its happened AGAIN! Same thing, fab up a new one (this time added clamp where clip was on side of frame) and again at about 130 click click click.. this time smoke too! ripped the CV boot and grease on the exhaust smoked up..
Anyone have this happen?
PS Its the drivers side and the axle was not a genuine GM, replaced with one from schucks or auto zone a while back because CV boot had a pin hole and spewed grease.
-Ken
-Ken
I have read about other people having trouble with the CV joint boot rubbing a hole in the brake line. You need to make sure it is routed so that there is plenty of clearance.
You might also check to see if the CV boot is the same diameter as stock.
I bought a 2000 with lines that were all over the exhaust (someone jacked em all up) so I routed them straight back above the diff and out above the exhaust, along the bottom of the rail that the rear sub bolts to and into the brakeline mounted in the stock position. I am sure this routing will keep my lines away from both exhaust and prop shaft.
-Ken
-Ken
-Ken
Hey Ken, old post but taking a chance that you're still monitoring it. I just had the exact same experience with my 2001 z06. Replaced the drivers side axle half last month because it was leaking around the band. Also used non GM part though not sure of the brand. I was at the track yesterday and all of a sudden heard a loud clicking noise. Pulled into the garage to find the brake line wrapped up in the CV boot. Bent it back into position, went back onto the track and not even one full lap around the track and it happened again. Decided to call it quits for the day and loaded it back on the trailer. Upon taking a better look at it today I noticed one of the retainer clips that holds the brake line to the subframe had broken off. I also found that the sides of the boot must have been rubbing on the subframe, there was a pile of rubber shavings on the frame and the edges of the boot were flattened.
Just curious if you discovered the root cause. I'm leaning towards the boot on the replaced axel half being slightly larger than stock bit was also wondering if the diff could be twisting enough to cause the boot to make contact with the brake line.
-Andrew
-Andrew
+1. The Aftermarket ones are softer than OEM and they balloon out at high speeds. On my old race car, we used to tie a string around each groove in the boot and put a drop of super glue on each knot.
happen to me a couple times. my lines are all goofy from custom coolers, and being apart so many times...ect... I think my issue is, when gaining big speed, those boots grow and grab the line. my last time, the line turned into a weed wacker and took out the main wiring harness.....that was fun
