Low RPM grind - Every Gear
If it's just making a funny noise but shifting fine I don't know if I'd worry about it.
However,,,I have found that If the tranny fluid is contaninated and worn changing the tranny ATF, normaly resolves that issue. Up-grading to a synthetic ATF really smooths out the shifting!!
The bad part is,,,you dont know how long that this issue has been going on and how worn the synchros are. If you have a warranty,,,,see if they will rebuild the tranny.
If not, change that ATF to some AMSOIL Sunthetic ATF!
