What would CF do? (kablamy!)
Hello Rod, meet LS1. LS1, Rod. I know you guys have always been close but have never gotten to know each other but... Well you seem to have HIT it off on the right note!!!
In case that makes no sense to you, I sent a rod through my block
So, what would CF do? 6k being the budget! I am already pretty set on what I am going to do, but I am just interested to see what you would do in my current situation.
BTW, the LS1 had 123k miles on her. It had been heavily raced, and heavily modified (h/c/i just about every bolton you could dream up).
Crate motor.
Conversion harnesses.
Sprinkle in cam and springs, SFI dampner, intake/exhaust, and a tune.
Add a z06 rear and doing 11's all day long in Phoenix.
My aluminium under drive pulley was sitting still, and the engine was running
So we replaced the pulley, and pinned the crank. The car was running EXCELLENT after this, had no problems, and was having a blast. So I was taking a buddy for a ride (never been in a vette, at all), go through first normally, hit second and go WOT. Clutch in at about 6500-6700, and KABOOM!
We're thinking that the crank had shaved just enough metal off into the oil to ***** my engine... I know I know, I didn't change the oil. Honestly, was just enjoying the drive so much (it had been down for a month), that I just forgot... So I don't think the LS1 just went, I think my not changing the oil after pinning, is what cause my problem.
As much as all this sucks, I am fairly certain I will be building a:
402 LS2 stroker (scat/eagle), with CNC'd DART 225 heads, and my mamo ported FAST 90, and ported TB. I'll be using my current headers, which will cut down on my HP a bit, but could possibly raise my torque, who knows. The goal is 525rwhp, with the option to run a low boost turbo setup (less than 10 pounds), and try to make 680-700rwhp.
So i'm sad, I was really enjoying it... Buuuuuuuuuuuuuut it's upgrade time!
Oh, and sorry no pictures right now... car's just sitting right now, we'll take it apart when I figure out what I want to do. That said, anybody want to buy a cam?
Can't wait to get it installed and tuned.
Cam: http://www.futralmotorsports.com/fms...asp?pf=3&pg=29
FMS F14 - 232"/234" .646"/.612" 112LSA - aggressive profile with a 3000-7000 RPM range, rough idle
Cam is still in the car, and I've no idea when I might be pulling it out. When I do get it out, $250 shipped?
Who knows though, every 24 hours my opinion changes
Also MattB, TSP will probably be doing the tuning on whatever engine I go with. However, SDPC will be doing the rest. Both great companies, I just have a more established relationship with SDPC. Can't go wrong with either.
Can't wait to get it done, the heart breaker though is a NASA event this weekend and no Vette to drive
Next event hopefully.IMO at this point in the year, my feeling is to get it done right rather than now. Good luck with whatever way you go
TSP & SDPC are in the same city as I live, so I've got the best of both worlds within 15 minutes ^_^.
How much did you budget for your 416? I won't be needing a clutch, springs, heads, intake, or push rods, but I am still going to budget $6k, which should be plenty.
