Both of my front Perelli P Zero/Neros have slow unfindable leaks. They loose about 5 psi per week. First I unbolted both and looked very carefully at each tire for the telltale nail or screw and found nothing. Then I took the LF to the biggest and maybe best tire store chain in the Boston metro area to break it down, and find the leak. They said it was becase of pound on weights, and that was what causing the pressure loss. Then they charged for glue-on balance weights.
It wasn't the case because the tire is acting just the same, about a 5 psi loss per week.
Would Slime or Fix-A- Flat be OK for the pressure sensors, or would that ruin them?
Thanks for your consideration,
Bluemill
What methods have you used? Have you tried inflating the tire to max pressure(molded on the sidewall on the sidewall) for the purposes of soaping it down. More pressure may accelerate the leak so it is detectable.
Fix a flat is a temp solution until the tire can be repaired.
Lucky makes a good suggestion. Remove the tires, pressure them up to the max, but instead submerge them in a kiddie pool (or some other large container of water) and look for bubbles. If that doesn't find them for you, I don't know what will. Good luck with your search.
Another simple thing to check for is the shrader valve in the stem. Take the cap off, spit on your finger, and rub it in the valve stem opening. If the shrader valve is leaking it will bubble. If that doesn't appeal to you any liquid soap will make a good leak tester too.
I keep a bottle of my saliva in the garage just for this purpose.
The first thing I would not do is using any slime fix in my tire because yes it will not only clog hole or leak it will damage tpms. The best thing to do is like what most have posted, add some extra air in the tire and submerge the tire in a small kiddie pool or get an old spray bottle and empty it, add water and some dish detergent. Spray the entire wheel , tire slowly and look for air bubbles to find your leak. If you find no leak on tire surface lay the rim flat down and spray side wall, and beading area and rim and valve stem area , removing valve stem cap, Rust or dirt around the rim will cause a slow leak too and if tire bead was not cleaned it may be leaking too. Next flip rim completely over to other side and do same spray technique. If your rim is leaking around the rim due to dirt or rust clean the rim with a plastic stiff brush , you can also get a better seal if you put a small amount of grease or vaseleine around the bead. Good Luck Richard
Fix a flat, etc is not recommended for use in Michelin/BFG hi performance tires. Hubby works at BFG. Fix a flat says so right on the can. Don't know about other brands.
Don't use fix a flat. It may damage the TPMS but if you do use it and find a nail or screw in your tire the chances of having a solid plug/patch put in are slim. The fix-a-flat binds to the inner tire and causes havoc when trying to get a good seal using a plug or patch.
Best bet to find a slow leak is to put some water and dish soap into a large tub and the spin the tire through the tube very slowly checking the tire for any bubbles. You want to check the part of the tire that is not submerged for any bubbles on the surface of the tire. Take extra time to look at the bead as I'd put good money it was either at the bead or the valve/valve stem. It may take some time but you'll find it.
I worked in a tire shop for 5 years and saw one or two cases that using the above method didn't work for finding a leak.
Also, try inflating the tire to a higher pressure but, keep it on the car and let the weight of the vehicle help you. If you spray the tire with a soapy water solution and find no leak . . . move the car a little bit so the weight is on another portion of the tire and spray again (if needed).
I had a slow leak for the longest time and found that it only leaked when the car was on a certain part of the tire.
SUBMERGE The tire under water. If the air is leaving, it has to make bubbles.
Places that I have seen very slow leaks are;
- Valve stem/TPS to rim seals defective. NOTE! The retainer nut that secures the TPS to the wheel has a specific TQ. ( I believe its in inch pounds) DO NOT OVER Torque that nut to try to stop it from leaking!!
- Shrader valve not tight inside the valve stem
- shrader valve damaged or dirty (there replaceable)
- Tire rim to tire bead seating surface dirty or pitted
- Crack in rim!!
- Pin hole leak in the tire
Check for all that stuff.
BC
Try replacing the o-ring on the TPMS sensor or slightly tightening the sensor nut a bit. See if this helps. On my 99 one of my tires loses air during the winter months because of the cold. It seems that the o-ring contracts a bit and allows air to escape. I tightened up the sensor nut and it slowed the leak down considerably, from 5lbs a week to 5lbs a month. the permanent fix would be to replace the o-ring in my case.
If you do use slime, I believe there are types that are water soluable and can be cleaned which would be a better option. Read the labels and see if it is safe to use with TPMS systems.
Also what year is your car? Early models came with o-rings on the sensors, and later models came with a grommet style on the sensor. The grommet style seemed to be a better design than the o-ring style, better sealing surface.
Could be you have the same problem I had. Tire would lose pressure slowly and could never get it to show a leak. I finally tightened the vale stem nut(part of the tire sensor on my 04) and sure enough the leak stopped. The sensor has some weight to it and at rest the o-ring will seal around the valve stem. At speed however, the centrifugal force causes the valve stem to offset just enough to let air out. Try tightening the nut around the valve stem a little.
In the old days, I found that tire sealant was a good way of fixing slow leaks. But when I tried that on my vette with TPMS, I ruined the sensors. I don't recall what brand I used, but I would advise against it.
My root problem was the chrome plating was flaking off my aftermarket rims. I finally gave up and put the old wagon wheels back on.
