Tire sensor error... HELP
Old Feb 22, 2002 | 12:59 PM
SPEED FREAK's Avatar
SPEED FREAK
Default Tire sensor error... HELP
OK I had my tires replace and I guess the tire shop did not reset the air sensors. Do any of you know what this is? I’m getting an error of please “service tire sensor monitoring system”. I took it to the Chevy dealer and they said the sensor need to be relearned. I guess the tire co should know about this reset when they change the tires. Any info would be greatly appreciated.
Old Feb 22, 2002 | 01:03 PM
GR8-LIFE's Avatar
GR8-LIFE
Default Re: Tire sensor error... HELP (SPEED FREAK)
The good news is there is defintely an easy way for the ReLEARN 'cause I have read similar posts to this. Unfortunately, I don't recall what it is but hopefully someone will chime in.
Old Feb 22, 2002 | 01:17 PM
Purerock105's Avatar
Purerock105
Default Re: Tire sensor error... HELP (Ha-Ha)
You can do it yourself provided you have a BIG enough magnet. That's right
a magnet is used to 'reset' them. It takes 5-minutes if that. Most dealers will
just do it real quick without charging...
Maybe you have an old speaker magnet at home. Try that first.
:cheers:
Old Feb 22, 2002 | 01:56 PM
batmann's Avatar
batmann
Default Re: Tire sensor error... HELP (Purerock105)
I would also be interested in this process.
I (not a tire shop) will be installing my old (98) sensors in a new 2002 wheel/tire set that I just purchased.
You mentioned using a large magnet. Then what?
Old Feb 22, 2002 | 02:12 PM
mnasrallah's Avatar
mnasrallah
Default Re: Tire sensor error... HELP (batmann)
go to this thread
http://forums.corvetteforum.com/zero...rint&id=235782
To Tire sensor error... HELP
