Fluid Temps, PSI ranges....
Old Sep 28, 2009 | 08:19 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Default Fluid Temps, PSI ranges....
Just a little something I did today on a 65mile run, all interstate, no stop signs, red lights, averaged at least 80mph the whole way, after about 2/3s the distance I went through the DIC and noticed pressure/temps. I have a 160t-stat, Ported LS6 oil pump, and a few other things listed in my profile, with outside temps at 92-94*, I'm running the A/C: Here's the readings:
Oil pressure.....52PSI
Oil temp...........212
Coolant temp....185
Tranny temp......199
Volts..................13.6
Tire pressures Non-R/F, are 30psi-cold, on the run they consistently stayed at 33psi, all 4.
Just an observation I am sharing.
