Electro Chromatic Mirror Dimming Question - noticeable difference ???
Old Feb 22, 2002 | 04:07 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Default Electro Chromatic Mirror Dimming Question - noticeable difference ???
OK boys and girls. The electro chromatic mirror on my 2001 coupe doesn't seem to be functioning. Is the dimming effect really noticeable ? I do not seem to be getting any visably different effects with a following car at night, or dusk. Any comments would be appreciated. I am going in to my local dealer next month for some other warranty work and if it's not working, I will get it replaced. Thanks ! :D
Old Feb 22, 2002 | 04:14 PM
DanG's Avatar
DanG
Default Re: Electro Chromatic Mirror Dimming Question - noticeable difference ??? (CHJ In Virginia)
You should be able to tell. When the mirror dims, it has a greenish tint to it. A couple of things to be aware of. First, the dimming and brightening are slow, so you might not notice the transition. It takes about 10-15 seconds to go from fully bright to fully dim.
Second, one of the switches on the mirror enables or disables the auto dim feature. You need to make sure it is turned on.
Third, if there really is a problem, notice if the driver side mirror dims. Both the rearview mirror and the driver side external mirror should be dimming.
Old Feb 22, 2002 | 05:06 PM
pjazz's Avatar
pjazz
C6 of Year Winner (performance mods) 2019
Default Re: Electro Chromatic Mirror Dimming Question - noticeable difference ??? (DanG)
Sounds like he covered all the bases. :yesnod:
Old Feb 22, 2002 | 07:05 PM
Untouchable00's Avatar
Untouchable00
Very much so at night, very noticeable!!!
To Electro Chromatic Mirror Dimming Question - noticeable difference ???
