Front corner lights help needed
Old Sep 29, 2009 | 03:10 PM
litpy's Avatar
litpy
Default Front corner lights help needed
I just ordered a set of front corner lights and they came without instructions, does anyone have a write up or instructions they could post? I had someone tell me I would have to remove headlights.
Old Sep 29, 2009 | 03:50 PM
DeeGee's Avatar
DeeGee
Here you go
Document ID# 655625
2002 Chevrolet Corvette
________________________________________
Park/Turn Signal/Side Marker Lamp Replacement
Removal Procedure
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
2. Remove the front fascia lower closeout panel.
3. Release the brake caliper cooling duct from the front fascia, and position the duct aside.
4. Remove the front turn signal lamp bracket retaining spring from the lamp bracket.
5. Remove the lamp bracket retaining spring from the front fascia.
6. Remove the front turn signal lamp bracket retaining screws.
7. Disconnect the sockets from the lamp.
8. Remove the lamp, with the bracket, from the vehicle.
9. Remove the lamp to bracket retaining screws.
10. Remove the lamp from the bracket.
Installation Procedure
1. Install the front park/turn signal and sidemarker lamp into position on the front turn signal lamp bracket.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
2. Install the front park/turn signal and sidemarker lamp to bracket retaining screws.
Tighten
Tighten the front park/turn signal and sidemarker lamp to bracket retaining screws to 2 N•m (18 lb in).
3. Install the sockets to the lamp.
4. Install the lamp, with the bracket, to the front fascia.
5. Align the lamp to the opening in the front fascia and hold the lamp firmly in place against the fascia, while installing the front turn signal lamp bracket retaining screws.
Tighten
Tighten the front turn signal lamp bracket retaining screws to 3 N•m (27 lb in).
6. Install the lamp bracket retaining spring to the front fascia.
7. Install the front turn signal lamp bracket retaining spring to the lamp bracket.
8. Position the brake caliper cooling duct to the front fascia and press the duct toward the fascia to secure.
9. Install the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
Old Sep 29, 2009 | 03:51 PM
Daddyrama31's Avatar
Daddyrama31
You do not have to remove the headlights. Go here http://forums.corvetteforum.com/c5-t...with-pics.html
Post #3. Good luck to you sir,
David
Old Sep 29, 2009 | 03:59 PM
2EZ 2SPD's Avatar
2EZ 2SPD
I did mine using these same instructions took about 15 to 20 mins per side just make sure your car is safely high enough to get under
Old Sep 30, 2009 | 07:31 AM
litpy's Avatar
litpy
Thanks guys for all your help, that will be my weekend job since we are going to have such beautiful weather here in Mi. 60 and cloudy with rain showers
To Front corner lights help needed
