Replacing right window motor
Old Feb 22, 2002 | 05:25 PM
Jerryk's Avatar
Jerryk
Default Replacing right window motor
Looking for help on replacing the right (pass) window side motor. My question is I dont know how to remove the two window cables that attach to it. Now when I buy the replacement unit do you need to disconnect the cables? or does it come apart and the cables need not be disconnected to replace the motor... :crazy:
Old Feb 22, 2002 | 06:30 PM
Gary2KC5's Avatar
Gary2KC5
Default Re: Replacing right window motor (Jerryk)
Sorry can't answer your questions, but can add some other advise.
The dealer didn't bother to duplicate the adjustments on the original motor (they called it a regualtor) an my window tip in adjustment was way off.
You should duplicate the window tip in adjustment from the old unit to the new unit so your window will be properly aligned.
Old Feb 22, 2002 | 08:10 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The motor and the regulator and cables is sold as a complete unit :yesnod:
To Replacing right window motor
