LS1-edit help needed.....
Old Feb 22, 2002 | 07:30 PM
DUKE's Avatar
DUKE
Default LS1-edit help needed.....
There has been so much interest in the LS1edit tool that I wondered if we could talk someone, who has done programming with that thing, into posting some "how to's" in a thread. Maybe C5specialist or someone like that who has a brain as large as their gonads :D (The means he has a big brain) That could be taken in the way it is not intended. However, I either need for Cole to come through with the PL that he has had since last year in Nov or pull the PCM and send to Ed Wright or .....buy that LS1edit and become profecient enough to do some minor programming like idle from 550 to 850, shift points, etc. Going to call Norris again and aggraviate him with more novice questions. Find out what he thinks about that tool. In the meantime, back at the ranch...some of you smart guys step up here and tell us gearheads how to use that LS1edit.Thanks. :)
[Modified by DUKE, 5:32 PM 2/22/2002]
Old Feb 22, 2002 | 07:38 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Default Re: LS1-edit help needed..... (DUKE)
There is a forum devoted to PCM tuning at LS1Tech.com. KenK even visits there. :) Also, I don't think c4c5specialist could be coaxed into saying much about LS1-Edit, even with a coffee bribe :D
Old Feb 22, 2002 | 08:05 PM
C5Owner's Avatar
C5Owner
The simple stuff you are talking about is very easy to do and laid out okay from an enduser standpoint. It actually uploads the program pretty quickly. You do need autotap to log your conditions to keep on top of your program. A friend has it and I've looked over his shoulder and stuff. A very nifty program.
To LS1-edit help needed.....
