I think I might have found a fix for a problem. I tried to release my trunk lid when the tonneau cover was open. All I got was some nice chimes. I know this is normal. But when I went to release the tonneau cover again the switch didnt work. The relay and fuse were both fine, but after replacing them the swith release worked again. I had them out for at least 10 mins. I am wondering if trying to open both lids at the same time scrambled the BCMs brain, and removing the fuse allowed it to reset. The tonneau switch was fine till the chimes, didnt work immediately after despite repeated attempts, the only thing I did was remove the fuse and relay. Is this another case of having to reset our friendly BCM?
It only happened because I did not realise my tonneau lid was not properly latched. What I am wondering is if the BCM was reset by removing the fuse from this curcuit, so allowing the latch switch to work again.
