Oil Pressure sensor questions
But from all the ones im reading through i think this is a bit different.
I know there quite a few problems where people get 0 or 130 PSI from the sending unit needing replaced.
Im looking for the possibility or experience that people have some that are mis calibrated so to speak.
I have had what i consider low oil pressure 26 hot at idle .. aruound 36 with higher RPMs. Ive seen a ton of cars that seem to have 10-15 more across the board
With a ported texas speed LS6 oil pump. i expect to see a substantial increase .... Instead im seeing around 40 -56 or so when hot.
Was told by quite a few folks that i could see up to around 80 with the new pump....
Anyone have some hard figures to can compare too ... i think im talking with to many bench techs
The stock bypass in the block is set for 72 psi.
The LS1 does not carry as much pressure as old V8's (LT1) were the rule was 10 psi for every 1,000 rpm.
Most garages have a mechanical oil pressure gauge that screws in between the oil filter and the block, or you can buy this, if you really want to check calibration. BUT, I'm betting it is okay.
My stock 1998 C5 runs about 25-35 psi at idle and 45-50 psi at rpms.
