Help with CCW wheels & tires
Old Oct 5, 2009 | 02:30 PM
6spdchevy's Avatar
6spdchevy
Default Help with CCW wheels & tires
I just came across a set of CCW classic wheels and almost new tires for $1300... This seems like a great deal to me, but the tire sizes are 315/30ZR18 up front and 335/30ZR18 in the rear. Will these fit my C5 without modification? If so, will they look rediculous? Any help will be appreciated!
Old Oct 5, 2009 | 02:35 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Nope you need a mini tube to fit the rears and the front wont even come close to fitting. Are you sure those wheels are C5 offset? Sound like Viper or something?
Old Oct 5, 2009 | 02:45 PM
6spdchevy's Avatar
6spdchevy
The guy says they are off of a C5 that was used for SCCA. Still doesn't seem right to me.
Old Oct 5, 2009 | 02:48 PM
0Cajun @ Edgyvette
Former Vendor
Guess it is possible. Have you seen them? If they were race wheels I am sure they are ragged pretty good. For that price they should be. Hell you could get them, polish them up good and have a decent setup if the wheels are not wider than 11 up front and 12 in the rear you should be alright. Might want to wait for some wheels gurus to chime in or visit the racing section. Those guys know for sure how far you can go before mods must be made.
Cajun
Old Oct 5, 2009 | 02:54 PM
AU N EGL's Avatar
AU N EGL
Nahh
Just take out the rear brake duct for the 335s
315s fit up front, but unless your running -2* camber or more like -3* camber they will stick out a bit
Old Oct 5, 2009 | 03:11 PM
6spdchevy's Avatar
6spdchevy
I've just seen pictures. They seem to be in good shape. Says the center caps are not original with the wheels. Remove brake ducts?
Old Oct 5, 2009 | 03:17 PM
AU N EGL's Avatar
AU N EGL
Yup
Remove the rear Z06 brake ducts. The inside parts, if you have them.
rear 315s or 335 s wont fit with the brake duct in place
Those look in great shape.
Mine are more 'seasoned" then those
Old Oct 5, 2009 | 03:25 PM
6spdchevy's Avatar
6spdchevy
Nice! Mine isnt a Z06. Does the C5 coupe have the same clearance?
Old Oct 5, 2009 | 03:56 PM
AU N EGL's Avatar
AU N EGL
It will be tight.
I run simular
front
18x12 with either 18x305/30 or 18x315/30
Rear
18x13 with 18x335/30 or 18x345/30
in front forget turning lock to lock, it cant be done. Especially with front brake cooling ducts
so dont turn lock to lock
Rear, you WILL rub out your inner wheel well line. Big deal No one looks in there
Question to ask the seller is
"How many heat cycles on the tires?"
R compounds are not measured in miles but heat cycles
Old Oct 5, 2009 | 04:41 PM
6spdchevy's Avatar
6spdchevy
Thanks for the advice guys!
Old Oct 5, 2009 | 09:06 PM
JonLT4CE's Avatar
JonLT4CE
It depends on the offset of the wheels. I have CCW classics and have run 335's all the way around. Front hit the fender lip on a hard bump but no rubbing on the rears (no tub).
I don't recommend 335's up front. Turn-in sucks.
This was track-only BTW.
Jon
To Help with CCW wheels & tires
