LSX truck coils
Old Oct 9, 2009 | 11:19 AM
  #61
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by thetaxman
it's engineers who try to be the end all , know it all
it's the techs who fix their screw-ups
been there
done that
same as architects and carpenters
Again, it's just more opinions, with no facts or data to back it up.
I give up. I've tried to have a technical discussion here, and all I get is shadetree mechanic opinions and old wive's tales.
Old Oct 9, 2009 | 11:49 AM
  #62
thetaxman's Avatar
thetaxman
Originally Posted by m-nelson
I come here to read interesting bit from fellow hobbiest, but this interchange is rather distasteful. Please give it a rest.
no worries
Originally Posted by lucky131969
Gotta laugh at that, my buddy says the exact same thing. We were both pursuing a mechanical engineering degree at U of Illinois, and he couldn't handle the calculus, so he had to get an accounting degree......
I'm not your buddy so what he did is irrelevant
Settle down mom....
Originally Posted by Eric D
I'm still waiting to see the Youtube with the dyno pull video of the before and after coil change! Then I'll be a believer....
you won't EVER see that
shadetree ?
I did it professionally for years on prodution cars and still get paid to build/work on race cars
so in your infinite wisdom you are going to say coils add HP ?
you have data ?
show us a dyno pull where coils MAKE HP
Old Oct 9, 2009 | 11:50 AM
  #63
FSTFRC's Avatar
FSTFRC
Originally Posted by carboy
are you kidding? This is fun.
Or are you just trying to avoid an audit?
lol!
Old Oct 9, 2009 | 11:53 AM
  #64
thetaxman's Avatar
thetaxman
Originally Posted by CarBoy
Are you kidding? This is fun.
Originally Posted by FSTFRC
lol!
I was laughing too
Old Oct 9, 2009 | 03:44 PM
  #65
06x6spdGTO's Avatar
06x6spdGTO
I talked to My Dad who has a Degree From Wyo-Tech. Told me that the coil is the LAZIEST Piece in the entire ignition system and the only way a coil will make any difference in power is if you are going to install a Multiple Spark Ignition Module.
Then he told me that if you want to see dyno gains Max your spark plug gap. Probly wont last long on a street car but if you have a DRAG Queen theres some power to be had.
Old Oct 9, 2009 | 04:12 PM
  #66
69427's Avatar
69427
you have data ?
Go back and re-read post #47.
I'm getting the strong impression that reading comprehension skills were not a requisite for graduating from auto tech school.
Old Oct 9, 2009 | 05:13 PM
  #67
fallen's Avatar
fallen
From: Upper West Side, NY Very Downtown Houston, TX
someone needs to do an A-B-A test. Then we will know for sure.
I would love to do this on my 440 high compression stroker.
FYI-Accel also sells truck coils. From their description seems like they are modified truck coils.
Old Oct 9, 2009 | 05:54 PM
  #68
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
And that's where a stronger coil can be beneficial too, you could run more gap.
Not sure if any of you watched this video, it's a little long at 19 mins, but it's pretty cool, especially the last couple minutes of it, where they have the truck coil firing a plug gapped at .130" at high RPM. Watching the difference in spark intensity as he changes dwell is interesting as well. (seems to contradict what thetaxman claims).
http://video.google.com/videoplay?do...65754251&hl=en
Of course that is in free air...the compressed charge in the cylinder isn't quite as kind to promoting ignition.
Old Oct 9, 2009 | 06:59 PM
  #69
thetaxman's Avatar
thetaxman
exactly
Old Oct 9, 2009 | 07:43 PM
  #70
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
exactly
So varying spark intensity is only possible in free air, but isn't in the combustion chamber?
Old Oct 9, 2009 | 07:46 PM
  #71
Warp Factor's Avatar
Warp Factor
Not necessarily. The electricity will take the path of least resistance. Once resistance across the gap becomes greater than the resistance of traveling down deposits on the insulator to ground, guess what happens?
Old Oct 9, 2009 | 08:06 PM
  #72
thetaxman's Avatar
thetaxman
the combustion pressure determines the spark
if that has changed let me knoiw
like I said , auto tech was 25+ years ago
bad coils cost hp
a good coil will not add any
Old Oct 9, 2009 | 08:08 PM
  #73
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Absolutely agree with that.
I'm not saying gap your plugs to 1/8" and reap the benefits...but with stronger spark (which is heavily dependent on the coil), running a bit more gap is certainly feasible.
Old Oct 9, 2009 | 08:26 PM
  #74
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
bad coils cost hp
I'm disappointed. You stated it correctly before, and now you stated it wrong.
Can't you at least be consistent?
Old Oct 9, 2009 | 10:07 PM
  #75
CarBoy's Avatar
CarBoy
Saw that Video and wondered if anyone would comment on it here.
Seemed pretty interesting to me. I would say that using the truck coil wouldn't be a bad thing, and seems like it would be more cost effective than some of these high priced after market coils.
Wonder if they would be strong enough to run a consitant gap on a plug like this.........
Those make a nice ball of fire on them
Old Oct 9, 2009 | 10:19 PM
  #76
69427's Avatar
69427
Not necessarily. The electricity will take the path of least resistance. (Actually, it takes every available path, not just one.) Once resistance across the gap becomes greater than the resistance of traveling down deposits on the insulator to ground, guess what happens?
Well, not really. The gap will always have a greater resistance. By definition, the gap resistance is infinite. The insulator resistance, however, will vary from infinite on down to a few hundred thousand ohms (ballpark numbers), depending on the level of fouling.
The "soot" and deposits on the plug insulator are obviously resistive shorts across the gap. During the (reasonably short) time that it takes the coil to raise the secondary voltage to arcover level, the plug soot is leaching coil energy to ground. The more energy stored in the coil, the more that is left (after the leaching and after the gap arc starts) to be imparted into the air-fuel mixture. That's a key element in the old High Energy Ignition system. (Note that it was not labeled High Voltage Ignition.) Any old system will create a high enough voltage to arc the plug gap in new plugs. It is the extra energy, not voltage, in newer systems that allow the engine to keep running for miles and miles after the plugs have fouled or worn to the point where an old points system would allow misfires due to insufficient energy being imparted into the air-fuel mixture.
Old Oct 10, 2009 | 07:48 AM
  #77
Warp Factor
Are secondary voltage rise time, and total energy both factors then? Can rise time be controlled? For example, are points a less "instant" switch, affecting rise time?
To LSX truck coils
Old Oct 10, 2009 | 09:50 AM
  #78
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by Bill Curlee
Chicago1
Im interested. My 02 ZO6 is down hard BUT,,,,,I just had my 06 Z51 coupe tuned and I want to get it re dyno tested.
I installed headers and a VARARAM a while back and it was running very rich. It only dynoed at 365 RWHP & 365 TQ. It was pig rich and had some serious engine knock.
Its tuned now and this will be a good opportunity to do a couple of runs with the stock LS2 coils and then back to back couple runs with the D585 coils. That will give me the opportunity to see if the D585 coils effect the tune.
How much do you think that they will cost? Can you get the mounting brackets and harnesses so that the swap will only take a few minutes?
Let me know.
Bill Curlee
Im willing to do some testing. Just need to find some coils that wont cost an arm and a leg.
BC
Old Oct 10, 2009 | 11:37 AM
  #79
69427's Avatar
69427
You are correct on every point here. May I (in all honesty) say how impressed I am with the depth of your thoughts on this.
Now, to your questions/statements:
Due to fouling in the plug insulators, dirt/contaminants/humidity on the coil surface, and simple capacitance between the plug wire and any nearby metallic surfaces, there are numerous places that are trying their best to bleed off the energy stored in the coil (at the moment of intended spark. ie: end of dwell). A little extra energy stored in the coil compensates for these losses. Now, the quicker that we can get the coil secondary voltage to jump from "essentially nothing" and on up to the 10-30 kV point needed to arc over the plug, the less time there is for this energy to bleed away (in the form of small currents). Good coil design, with minimal internal capacitance, allows a faster risetime. Also, thanks to modern electronics, we can switch the coil primary current off damn quickly. This fast switching has several advantages in efficiency, allowing the coil to not only produce a higher voltage (if needed), but a quicker risetime. A limitation to the old points system was the points cam, compared to power transistors, just slowly and gradually opened up the electrical connection, and the condenser, while doing a remarkable job of protecting the points, gave a side effect of slowing the shutoff of the primary current. Slower shutoff means less efficiency and less available kV at the secondary. (There's formulas for this if anyone is looking for cures for their insomnia. ) Modern electronic modules don't use (or need) a condenser on the power transistor that controls the primary current. The elimination of the capacitance (the condenser), and the great speed that the transistor switches (compared to the points opening) allows greater speed and efficiencies in transferring the energy from the coil to the plug gap.
Old Oct 10, 2009 | 12:02 PM
  #80
06x6spdGTO's Avatar
06x6spdGTO
Called Lingenfelter Today and spoke to Jason he said there ARE no GAINS from Changing coils unless your old coils are bad. I think i will take the word of someone who builds Race CARS and has Engineering Degrees.
If you want to know call them. They have done the test on an engine dyno. BACK - BACK.
260-752-2552 ASK for Kevin or Jason
