99 c-5 pcv valve location
Old Oct 6, 2009 | 07:21 PM
2NDTOSEX's Avatar
2NDTOSEX
Cruising
Default 99 c-5 pcv valve location
Gent's if somebody could ping in where is the locale of the PCV valve?
The Gunny
Old Oct 6, 2009 | 08:41 PM
vettezeke's Avatar
vettezeke
Default PCV local
Its in the PCV tubing at the front of the intake manifold right side. Believe there is a ground strap hooked to it.
Old Oct 7, 2009 | 10:19 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
True. The strap that looks like a ground strap is actually there to transmit heat to the pcv valve. It connects the valve cover vent tubes to the intake port via the pcv valve. The connection tube from the pcv to the intake will eventually fail by collapsing and possible holes in it, especially on the bottom of it, out of sight. I found out the hard way.
To 99 c-5 pcv valve location
