do not buy - SIMULATORS
Old Oct 6, 2009 | 08:37 PM
dquagliaroli's Avatar
dquagliaroli
Default do not buy - SIMULATORS
Why spend $159 - over $200 for the priviledge of replacing F55 suspension. It can be done in minutes for far less money. Go to the
Tech section and read How to Deprogram F55 suspension. Took me over a week but it is so easy -
Old Oct 6, 2009 | 09:54 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It is when you have a Tech2
Old Oct 6, 2009 | 10:43 PM
capehorn3's Avatar
capehorn3
Old Oct 7, 2009 | 06:31 AM
Chris Lee's Avatar
Chris Lee
10 Ohm 10 Watt resistors from Radio Shack for $5. Wire them in. Problem solved.
Old Oct 7, 2009 | 07:00 AM
dquagliaroli
Default even better
Chris, I remember reading that same process once before but couldn't remember where or the specifics. If someone is going to bring the car to a GM dealer, in most cases they will be told it can't be done. Next time I'll try your recommendation.
Old Oct 7, 2009 | 08:06 AM
Chris Lee's Avatar
Chris Lee
I did it less than a week ago. I can tell you that it works.
Old Oct 7, 2009 | 12:22 PM
Chris Lee's Avatar
Chris Lee
Originally Posted by 8VETTE7
The resistors work for the F45 suspension but NOT for the F55 that is on the 03 and later cars.
I stand corrected. Good to know.
Old Oct 7, 2009 | 06:10 PM
dquagliaroli
Default you are right on
when your right - your right
To do not buy - SIMULATORS
