fuel line interchange
Old Oct 7, 2009 | 07:33 AM
Blow Torch's Avatar
Blow Torch
Default fuel line interchange
NO FLAMING HERE. I haven't compared them side by side, so I wanted to ask.
Can the later year style fuel lines with the plastic clip connections, be substituted for the earlier style fuel lines that had to use the "tool" to remove them if I simply get the plastic clips and install on the line?
Old Oct 8, 2009 | 07:23 AM
Blow Torch's Avatar
Blow Torch
No ??
Old Oct 8, 2009 | 10:42 AM
HP_Addict's Avatar
HP_Addict
when I installed 97-98 fuel lines on my 02, they both used the same push on connectors.
you do need a tool to remove the line at the fuel rail.
Old Oct 8, 2009 | 07:27 PM
Blow Torch's Avatar
Blow Torch
The ones I am working on are at the fuel pump. I need a fuel check valve, which is in one of the lines coming off of the pump. I have one of the later model pumps and the lines, and wondered if it would work.
To fuel line interchange
