Diagnostic Codes
Old Oct 7, 2009 | 01:57 PM
MGarofalo's Avatar
MGarofalo
7th Gear
Default Diagnostic Codes
Can anyone decode these from a 2001 Roadster?
A1-RDCM B2283 H
A1-RDCM B2285 H
A1-RDCM U1064 H
AO-LDCM B2262 H
AO-LDCM B2282 H
AO-LDCM B2284 H
AO-LDCM U1064 H
These codes were displayed via the DIC.
Old Oct 7, 2009 | 03:00 PM
87SAM's Avatar
87SAM
Are currently having issues or just checking? Have you had low a battery in recent history?
Old Oct 12, 2009 | 04:06 PM
MGarofalo's Avatar
MGarofalo
7th Gear
Having some issues and also checking. Headlights come on but don't always come up. If I turn off engine, raise manually then restart, everything is fine and returns to normal operation. Next, during daytime, HVAC display is so dim, it cannot be read. After dark, it is legible, but dim. Clock display is normal in light and dark. Wondering if error codes might be related.
Old Oct 12, 2009 | 07:09 PM
CARRJET's Avatar
CARRJET
try this
http://forums.corvetteforum.com/c5-t...-to-share.html
Old Oct 12, 2009 | 07:36 PM
Kick2TheJunk's Avatar
Kick2TheJunk
Navigator
Just got an 02 Convert myself... checked the DIC codes... all of mine said "H" after the codes. Looking around online, I found somewhere that stated the "H" means "History" ... or ... it's an old issue. If it says "C", then it's "current".
I'm guessing by the Autozone-Advance Auto Parts battery that the car lost 'communication' (most of my codes were lost comm) when the battery was changed out.
Then again, if this was Rocky Horror, I'd be going up on stage to pop a balloon right now.
Old Oct 13, 2009 | 12:59 AM
ALLEGRO's Avatar
ALLEGRO
A1-RDCM B2283 H
A1-RDCM B2285 H
A1-RDCM U1064 H
AO-LDCM B2262 H
AO-LDCM B2282 H
AO-LDCM B2284 H
AO-LDCM U1064 H
All of those are "history" codes and relate to bad voltage and loss of signal. Check your battery, or if it is old, REPLACE it and then clear your codes.
Old Oct 13, 2009 | 02:44 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
On the codes...
I'm not sure what's going on with your headlights, they could be binding somehow or the motors are weak... ???
For your HVAC display, if you're handy with a soldering iron;
http://forums.corvetteforum.com/c5-t...splay-fix.html
If not check JW Motoring... Supporting Vendor who offers the fix.
Old Nov 16, 2009 | 06:01 PM
MGarofalo's Avatar
MGarofalo
7th Gear
Wow!!! Thank you soooo much. Now I'll go study them.
To Diagnostic Codes
