Cruise Control Problem
Old Oct 7, 2009 | 06:13 PM
Stan-the-man's Avatar
Stan-the-man
6th Gear
Default Cruise Control Problem
I have a 2004 corvette. The cruise control is engaged for 2-3 seconds then disengages. Resume will engage for 2-3 seconds then disengage. Problem? Possible fix? Cost?
Thanks,
Stan-the-man
Old Oct 7, 2009 | 06:18 PM
lucky131969's Avatar
lucky131969
Thanks,
Stan-the-man
any codes?
Old Oct 7, 2009 | 06:53 PM
Stan-the-man
6th Gear
Default Cruise control problem
No codes. I have not had it checked out by a dealer. Dash read out only shows engaged then disengaged.
Stan-the-man
Old Oct 7, 2009 | 07:54 PM
lucky131969
What does that mean? Do you know how to check your codes?
Old Oct 8, 2009 | 02:10 AM
Stan-the-man
6th Gear
I am a new Corvette owner and do not know how to check out codes.
Any information would be appreciated.
Old Oct 8, 2009 | 09:22 AM
lucky131969
http://www.c5forum.com/ayc/dtcdic.php
Old Oct 12, 2009 | 07:46 PM
Stan-the-man
6th Gear
Finally getting some codes. Took the vette to a local repair shop, they said No Codes and switch was good, take it to a dealer. After leaving the shop cruise worked for about a day ???? With your info did the code check:
60 IPC B0516H, 99 HVAC B0363H, 99 HHVAC B0367H, A0LDCM B2252H, A0LDCM B2282H, A1RDCM B2283H, A1RDCM B2285H.
Do these codes help with the Cruise Control Problem?
Old Oct 13, 2009 | 12:56 AM
ALLEGRO's Avatar
ALLEGRO
The B 0516 is a speedometer circuit malfunction. Probably your second look.
B 2252 is a ket cylinder fault. Could be an issue.....not sure.
B 2282, 2283 and 2285 are a battery issue.....PROBABLY your first look.
B 363 and 367 are actuator errors in your hvac....again, could be voltage driven.
How old is your battery?
Good Luck
Old Oct 14, 2009 | 02:16 AM
Stan-the-man
6th Gear
Battery was replaced last year----should be good.
To Cruise Control Problem
