Dual Tempature Climate Control Problem
Old Oct 8, 2009 | 07:17 AM
STRODDER's Avatar
STRODDER
Default Dual Tempature Climate Control Problem
I have a 2001 with dual climate control, and the temp control on passenger side display, and temp will not change when turning the ****. Drivers side works OK and the A/C works great. Any Ideas on how to repair it?
I just bought the car and didn't notice that the passenger side wasn't working.
Old Oct 8, 2009 | 08:45 AM
Carcass's Avatar
Carcass
The display doesn't change with the pass. side ****,only with the driver side **** ,and the pass. temp will only change a few degrees.
Test the pass. side vents with a thermometer,you may find that they're actually working-it's not a night and day temperature difference
Old Oct 8, 2009 | 10:35 AM
STRODDER's Avatar
STRODDER
So you mean the passenger **** won't show you a temp change? I thought it should since my 03 and 06 Silverado does. I'll compare both side temps and see. The guy didn't give me the owners manual, and he's not returning my call.
Thanks, Dennis
Old Oct 8, 2009 | 11:54 AM
byronhunter's Avatar
byronhunter
Carcass is correct, and you can download a free owner's manual at gmpartshouse.com.
Old Oct 8, 2009 | 12:09 PM
dustinztx's Avatar
dustinztx
I agree with Carcass the passenger will only adjust the the degress + or - a few from what is set on the drivers temp and will not show in the display.
Old Oct 8, 2009 | 05:03 PM
STRODDER's Avatar
STRODDER
I just talked to the previous owner, and they said the same thing.
Thanks for confirming it. I'll down load the manual too
To Dual Tempature Climate Control Problem
